Date/Time: Sat, 01 Mar 2025 01:28:42 +0000
Windows blue screen stop code
View Count: 548
[2021-09-13 13:41:24]
User525965 - Posts: 153
I am having ongoing issue with Sierra crashing my computer and getting a blue screen with multiple different stop code errors.
I have tried everything from a hardward standpoint, I replace my hard drive for SSD, that didn't work so I bought a new laptop, then upgraded the memory and drives on my new laptop. I'm still having the issue. I don't know what to do, I can't keep having this happen, please assist.
[2021-09-13 14:20:55]
This is definitely not a problem with Sierra Chart, it is going to be an issue on your side with your system. It is not possible for this to be a problem within Sierra Chart.
And it is also hard to believe if you have a new computer your also experiencing the same thing. Maybe the problem is caused by a custom study but that would be extremely unlikely. Nevertheless, we want you to run Sierra Chart in Safe Mode:
Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface
And also if you are using OpenGL disable that:
Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other)
Date Time Of Last Edit: 2021-09-13 14:21:49
