Date/Time: Mon, 28 Sep 2026 08:29:02 +0000
FESX problem
View Count: 809
[2021-09-13 13:32:00]
User210074 - Posts: 63
Hello
I know the FESX has changed quotes.
I have a problem on the Dom for the depth of the market.
My version of sierrachart is 2299, I even did a "DELETE AND DOWNLOAD DATA".
The problem remains the same.
imageERROR_FESX_DOM.PNG / V - Attached On 2021-09-13 13:30:30 UTC - Size: 11.24 KB - 263 views
[2021-09-13 17:11:41]
Sierra_Chart Engineering - Posts: 24994
After this apply the symbol settings to that chart following these instructions:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
If you are not using the CTS software for trading, then you should pay for the EUREX exchange fee only through Sierra Chart and you will have a much better data feed. You can do this from here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliEUREX
Date Time Of Last Edit: 2021-09-13 17:15:13
