Date/Time: Fri, 02 Oct 2026 17:16:00 +0000
number bar calculated values study issue
View Count: 737
| [2021-09-13 09:47:27] |
| User278398 - Posts: 296 |
how can i make the background of the volume section (number bar calculated values study) to be change depend the the amount of the volume?(for example, for volume of 1000 i want to get blue color background, and for 2000 volume i want to get yellow color background) regards |
| [2021-09-13 10:31:13] |
You are making too many postings on this board and your account has been blocked for posting for the time being. You need to consult the documentation.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-13 10:31:31
