Date/Time: Sat, 01 Mar 2025 01:42:17 +0000
request for trial period renewal (15 day usage time)
View Count: 472
[2021-09-13 03:20:00] |
User918591 - Posts: 20 |
Hello, I'm discovring sierra chart since 15 days (through the 15 days trial period) but I still find that I have more basics to know on sierra chart. Can you please grant me another 15 days trial period? It will help me at least to have the basics to use sierra charts. Regards, |
[2021-09-13 10:24:11] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-13 16:57:24] |
Thank you for the renewal
