Date/Time: Sat, 01 Mar 2025 01:39:14 +0000
[User Discussion] - Is it possible for this software to have a Powerfull backtesting like In Ninjatrader8 ?
View Count: 559
[2021-09-12 14:54:42] |
GravisHTG - Posts: 306 |
I would like to know if its possible or it will never be possible as I will invest time and money into a good viable backtesting solution. I would love it to be on this software but if its will never be possible to have a monster backtesting capacity, I will plan accordingly. Or maybe have a PYTHON backtester that work with the software Spreadsheet and study from the program - like Sierra chart have an API that connect to the external backtester ( is that even possible ? ) Thanks in advance. ! Date Time Of Last Edit: 2021-09-12 16:06:23
[2021-09-13 12:44:25] |
Can the Dev tell me if this is possible or not ? This one will have to be on my side to check after if you got a kind of API that external program can work with.
Date Time Of Last Edit: 2021-09-13 12:51:19
