Date/Time: Tue, 26 Nov 2024 00:30:01 +0000
interference with indicators
View Count: 1069
[2014-03-24 20:21:23] |
User21223 - Posts: 92 |
Hi I have a problem with changing the settings indicators. I open the file studies.cpp by Notepad + +, for example, changing the data VolumeFilterGE.SetInt (3) on VolumeFilterGE.SetInt (10) gives the save. I open platform and continue in the indicators are standard settings. Do I even be able to change settings for Notepad +
[2014-03-24 22:42:08] |
This is not the right way to do this. For what you want to do, refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#CustomDefaultStudySettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
