Date/Time: Sat, 01 Mar 2025 01:38:50 +0000
bar size issue
View Count: 691
[2021-09-12 11:37:46]
User278398 - Posts: 291
hello,
what is the option to see bar size(high price bar-low price bar) on chart as i move over a specific bar in chart?
regards,
image55555555555555.jpg / V - Attached On 2021-09-12 11:36:54 UTC - Size: 47.76 KB - 183 views
[2021-09-12 12:57:20]
Refer to the Chart Values tool:
Chart Drawing Tools: Chart Values/Crosshair
[2021-09-12 15:04:46]
i want to see a label as i move over the chart/or just a fix label ( as like the attached pic).
there is option for this?
[2021-09-12 22:03:59]
John - SC Support - Posts: 38292
There is not an option to show a label as you move the pointer through the chart, Sierra Chart does not do this. You would need to use the Tool Values Window or the Compact Tool Values Window and have the True Range study on the chart. Refer to the following:
True Range
If you want to have the listing for each bar showing, then you can use the True Range study along with the Study Subgraph Above/Below Bar as Text. Refer to the following:
[2021-09-13 07:40:15]
there is an option to make the output font data label to be bold ?
as i can see i just have a choice to change size font
regards.
image455455545545.jpg / V - Attached On 2021-09-13 07:37:03 UTC - Size: 223.59 KB - 142 views
