Date/Time: Sat, 01 Mar 2025 01:41:29 +0000
Small bug : CountDown Timer wont keep is coordinate when we load Study Colleciton
View Count: 452
[2021-09-12 07:24:33] |
GravisHTG - Posts: 306 |
I save my Countdown timer in a study collection on the bottom left of my chart , But when I load that study collection in another chart. The countdown timer always go back to bottom right. thanks |
[2021-09-12 21:46:32] |
John - SC Support - Posts: 38292 |
We just tried doing a Study Collection with just the Countdown Timer set to display in the lower left and it consistently puts it in the correct location when we load the Study Collection. The other odd thing is that the default location for the Countdown Timer is the upper left corner, not bottom right. Unless you specifically changed the defaults for that study. But get us a copy of that Study Collection so we can take a look by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile You can attach the file as private so no one else can see if it you want to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-13 12:46:32] |
That position in the bottom right corner was the last position I had is save before changing it.
[2021-09-13 14:57:53] |
We would like to see the Study Collection to see if we can reproduce the issue.
[2021-09-13 15:07:55] |
i think i found the problem , its when I move the timer manually in my chart , it does not change the value in the study itself. where is the location of H : 115 V : 7 ? :) have a good day |
[2021-09-13 15:25:48] |
Yes, that is correct. Those coordinates are just the "initial" location setting.
