Date/Time: Sat, 01 Mar 2025 01:54:13 +0000
[User Discussion] - Info : A study that tell you How many time the price hit Current Price as it fluctuate.
View Count: 423
[2021-09-12 07:19:13] |
GravisHTG - Posts: 306 |
Do we have a study like that ? It is like the curren price study but It give you a number that tell you how many time the price hit that line base on the Day you have loaded on the chart and the number of bar you tell the study to check. You can even add a Number of tick up and down from the line. Like a box and it gives you how many time the box hit the price at that level before. the result can be put in a subgraph or/and on the current line. Maybe we can do a sweep of price compare to the Current price at each X number of time.And it gives multiple result. Do we have that kind of study ? Date Time Of Last Edit: 2021-09-12 07:20:17
[2021-09-12 21:39:00] |
John - SC Support - Posts: 38292 |
There is not a built-in study that does this. You would have to program it, or have someone program it for you. Refer to the information here: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
