Date/Time: Sat, 12 Sep 2026 06:08:46 +0000
Show value labels for past periods in period ohlc
View Count: 1262
[2021-09-12 05:12:36]
jinglebell - Posts: 5
Is there a way to get value labels instead of just dash of previous labels on period variable ohlc study.
for eg using 1 week period in ohlc, i only see low of current week as value label but not of any previous week. I do value on subgraph and it replaces dash with repeating first digit. I would like just a line with value label for each period
image20210912_000858.jpg / V - Attached On 2021-09-12 05:12:06 UTC - Size: 15.25 KB - 400 views
[2021-09-12 21:27:03]
John - SC Support - Posts: 47854
There is not a way to get the Value Label for previous periods to show up. It is always going to be just for the most recent item.
But, in order to display that information, you could use the Color Bar Based On Alert Condition and have it set to Value of Subgraph for the output. You would just have to work on your Alert condition to get it to only be true at the end of the week. Refer to the following:
Color Bar Based on Alert Condition
[2021-09-18 17:32:08]
I used to use motivewave prior and I liked this feature a lot , it would have me look at those monthly levels in a glance across multiple markets without having to use crosshair. I would request to have a setting for this feature going forward.
[2021-09-19 15:42:57]
We have set this as a Feature Request.
[2021-11-24 03:59:58]
Any idea how long it may take to implement
[2021-11-24 16:20:59]
We do not know. By tagging it as a Feature Request we are acknowledging that this is something that we would like to change/work on, but we can not give any timeframe for when this might occur.
[2022-01-24 14:10:28]
A feature specifically like that for this study would not be added.
You need to use this study instead:
Study Subgraph Above/Below Bar as Text
Date Time Of Last Edit: 2022-01-24 14:11:32
