Date/Time: Sat, 01 Mar 2025 01:23:52 +0000
Initial Balance Levels - how to prevent it from extending into the overnight session?
View Count: 474
[2021-09-12 01:29:25]
User8135477 - Posts: 133
Prior to the last version update, my Initial Balance levels were shown only throughout the regular trading hour session and hidden throughout the overnight session. This worked great, and it is what I prefer.
Now, since the last update, the levels continue throughout the overnight session.
I don't see an option to keep it the way it was before the latest update. If there is a way to revert it back, can you please advise. If not, can you please make available an option to keep it the way it was? It would be much appreciated.
[2021-09-12 21:23:23]
John - SC Support - Posts: 38292
This has not changed, therefore you should not be seeing anything different in the way that the IBR Extension lines are drawn.
Please attach a screenshot showing us what you see.
Also, check your Session Times to ensure that they do not overlap (make sure the RTH is not set to end at 16:00 and the evening session starts at 16:00, it should be 15:59 and 16:00 respectively).
[2021-09-14 01:36:27]
Actually, the menu under the Settings and Inputs has changed. The updated version allows for additional options. I did try adjusting each of them on a one-by-one basis to replicate the previous setting, but to no avail.
Yes, I've checked this as well, to no avail.
I've attached a side-by-side screen shot comparison. They are both on 24-hour charts. You will note that the previous version does not continue the IBR Extension line throughout the overnight session (which is what I prefer), whereas the latest update does show them.
Private File
[2021-09-14 13:37:34]
Can you please get us a copy of that chart so we can take a look at the settings you have for it. Follow these instructions:
