Date/Time: Sat, 13 Sep 2025 06:52:50 +0000
Interactive Brokers and Euronext
View Count: 795
[2021-09-10 22:53:16]
User395685 - Posts: 33
It seems I succeeded in linking SierraChart to TWS. However, in the "Find Symbol" window, I can't find stocks of Euronext. I only see US NYSE/AMEX/NASDAQ and BATS .
I subscribed to "Europe Equity and Derivative Display Value Bundle" which gives me access to Euronext data.
Where can I find these stocks?
Thanks.
[2021-09-12 19:05:02]
John - SC Support - Posts: 41793
Since these are equity symbols, you just need to type in the particular symbol you want using the Interactive Brokers nomenclature. Refer to the following:
File Menu: Find Symbol (File)
And then refer to the following:
Interactive Brokers Symbols: Stock Format
[2021-09-13 05:40:46]
I tried AIR-STK-SBF-EUR (for Airbus in SBF exchange) and I can see the daily chart. However, I also have the message "Symbol settings not found for current service". Why?
Date Time Of Last Edit: 2021-09-13 06:02:05
[2021-09-13 14:15:07]
It just means that there is not a symbol setting that exactly matches what you have entered. For instance, we see that there is a symbol setting for ???-STK-SBF, but there is not a symbol for ???-STK-SBF-EUR.
Therefore, you can just ignore the notice about not having a symbol setting, as it will not have an impact, or you can copy the ???-STK-SBF to ???-STK-SBF-EUR. Refer to the information here:
Global Symbol Settings: Duplicating Existing Settings for a Symbol
