Date/Time: Tue, 26 Nov 2024 06:55:00 +0000
Problem with SC real time feed. Price is reduced by an order of magnitude
View Count: 1325
[2014-03-24 18:36:30] |
User12676 - Posts: 70 |
Problem with SC real time feed. Check attached image. Price is reduced by an order of magnitude, whats going on.
screen.jpg / V - Attached On 2014-03-24 18:36:02 UTC - Size: 83.45 KB - 432 views Attachment Deleted. |
[2014-03-24 18:38:49] |
And no, delete all data and redownload does not help
[2014-03-24 22:01:34] |
This should now be resolved. Update the Global Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings In the case of Intraday charts, you will need to re-download all the data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-25 01:24:37] |
Following these steps resolved the problem with soybean futures. However, still have the same problem with corn futures. |
[2014-03-25 01:28:12] |
This should now be resolved for the corn futures (ZC). Update the Global Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings In the case of Intraday charts, you will need to re-download all the data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-25 01:42:13] |
Yes it is, thank you
[2014-04-15 07:43:41] |
This problem appears with the yen now with SC real time feed.
[2014-04-15 08:11:52] |
We need to know what particular Trading service you are using. Is it CQG?
[2014-04-15 20:29:48] |
Yes, it is with CQG.
[2014-04-16 07:35:03] |
We are checking on this now. The reason for the delay is that we need to set up access to the CQG data feed.
[2014-04-16 08:16:03] |
We are not seeing a problem with this. The price formatting looks correct: http://www.sierrachart.com/image.php?l=1397636141395.png Maybe you are looking at a different symbol? The best thing to do is to post an image of the chart, so we have a better understanding of the problem: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-16 08:28:42
[2014-04-22 02:40:00] |
I have missing data from crude oil now with SC real time feed with CQG. Heres a pic. I did delete all data and download, didnt help :(
screen.jpg / V - Attached On 2014-04-22 02:39:56 UTC - Size: 69.05 KB - 380 views |
[2014-04-22 03:47:29] |
Also, 10 year note data fails to load Software version: 1115 | 2014-04-21 18:45:29 Usage end date: 2014-05-17 | 2014-04-21 18:45:29 Enabled for: Sierra Chart Historical Data Service. | 2014-04-21 18:45:29 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-04-21 18:45:29 Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-04-21 18:45:29 Received 1 data feed usernames. | 2014-04-21 18:45:29 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-04-21 18:45:29 Active service: CQG Trading | 2014-04-21 18:45:29 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-04-21 18:45:29 2014-04-21 18:45:29 Local computer clock time | 2014-04-21 18:45:29 2014-04-22 01:45:29 GMT time | 2014-04-21 18:45:29 2014-04-21 18:45:29 Time zone adjusted time | 2014-04-21 18:45:29 Time difference to server time: 0 seconds. | 2014-04-21 18:45:29 Program path: C:\SierraChart\ | 2014-04-21 18:45:29 Data Files path: C:\SierraChart\Data\ | 2014-04-21 18:45:29 OS Version Number: 5.1 | 2014-04-21 18:45:29 Checking for new symbol settings for cqg | 2014-04-21 18:45:29 Symbol settings are up-to-date for cqg | 2014-04-21 18:45:29 CQG FIX Trading: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2014-04-21 18:45:34 Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2014-04-21 18:45:34 The network socket is connected. | 2014-04-21 18:45:34 CQG FIX Trading: Sending the Logon message. | 2014-04-21 18:45:34 CQG Trading: Connected. | 2014-04-21 18:45:35 Date rule based rollover from F.US.EPH14 to next contract occurs at 2014-03-13 | 2014-04-21 18:45:45 Date rule based rollover from F.US.EPM14 to next contract occurs at 2014-06-12 | 2014-04-21 18:45:45 Checking Intraday data file for symbol F.US.EPH14 for the date range from 2013-12-12 to 2014-03-13 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-04-21 18:45:45 Checking Intraday data file for symbol F.US.EPM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Symbols used for F.US.EPM14 continuous contract chart: | 2014-04-21 18:45:45 F.US.EPH14 | 2014-04-21 18:45:45 F.US.EPM14 | 2014-04-21 18:45:45 Volume based rollover from F.US.EPH14 to F.US.EPM14 occurs at 2014-03-14 | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 5000 Trades #2: Performing continuous futures contract back adjustment calculations. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 5000 Trades #2: F.US.EPH14 Open price on 2014-03-14 is 1847.25. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 5000 Trades #2: F.US.EPM14 Open price on 2014-03-14 is 1840. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 5000 Trades #2: F.US.EPH14 price difference to F.US.EPM14 is -7.25. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 5000 Trades #2: Back adjust amount for symbol F.US.EPH14 is -7.25. | 2014-04-21 18:45:45 Date rule based rollover from F.US.EPH14 to next contract occurs at 2014-03-13 | 2014-04-21 18:45:45 Date rule based rollover from F.US.EPM14 to next contract occurs at 2014-06-12 | 2014-04-21 18:45:45 Checking Intraday data file for symbol F.US.EPH14 for the date range from 2013-12-12 to 2014-03-13 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-04-21 18:45:45 Checking Intraday data file for symbol F.US.EPM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Symbols used for F.US.EPM14 continuous contract chart: | 2014-04-21 18:45:45 F.US.EPH14 | 2014-04-21 18:45:45 F.US.EPM14 | 2014-04-21 18:45:45 Volume based rollover from F.US.EPH14 to F.US.EPM14 occurs at 2014-03-14 | 2014-04-21 18:45:45 F.US.EPM14 [CBV] Delta 5000v #1: Performing continuous futures contract back adjustment calculations. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] Delta 5000v #1: F.US.EPH14 Open price on 2014-03-14 is 1847.25. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] Delta 5000v #1: F.US.EPM14 Open price on 2014-03-14 is 1840. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] Delta 5000v #1: F.US.EPH14 price difference to F.US.EPM14 is -7.25. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] Delta 5000v #1: Back adjust amount for symbol F.US.EPH14 is -7.25. | 2014-04-21 18:45:45 Date rule based rollover from F.US.EPH14 to next contract occurs at 2014-03-13 | 2014-04-21 18:45:45 Date rule based rollover from F.US.EPM14 to next contract occurs at 2014-06-12 | 2014-04-21 18:45:45 Checking Intraday data file for symbol F.US.EPH14 for the date range from 2013-12-12 to 2014-03-13 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-04-21 18:45:45 Checking Intraday data file for symbol F.US.EPM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Symbols used for F.US.EPM14 continuous contract chart: | 2014-04-21 18:45:45 F.US.EPH14 | 2014-04-21 18:45:45 F.US.EPM14 | 2014-04-21 18:45:45 Volume based rollover from F.US.EPH14 to F.US.EPM14 occurs at 2014-03-14 | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 30000 Trades #3: Performing continuous futures contract back adjustment calculations. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 30000 Trades #3: F.US.EPH14 Open price on 2014-03-14 is 1847.25. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 30000 Trades #3: F.US.EPM14 Open price on 2014-03-14 is 1840. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 30000 Trades #3: F.US.EPH14 price difference to F.US.EPM14 is -7.25. | 2014-04-21 18:45:45 F.US.EPM14 [CBV] 30000 Trades #3: Back adjust amount for symbol F.US.EPH14 is -7.25. | 2014-04-21 18:45:45 Date rule based rollover from ESM02 to next contract occurs at 2002-06-13 | 2014-04-21 18:45:45 Date rule based rollover from ESU02 to next contract occurs at 2002-09-12 | 2014-04-21 18:45:45 Date rule based rollover from ESZ02 to next contract occurs at 2002-12-12 | 2014-04-21 18:45:45 Date rule based rollover from ESH03 to next contract occurs at 2003-03-13 | 2014-04-21 18:45:45 Date rule based rollover from ESM03 to next contract occurs at 2003-06-12 | 2014-04-21 18:45:45 Date rule based rollover from ESU03 to next contract occurs at 2003-09-11 | 2014-04-21 18:45:45 Date rule based rollover from ESZ03 to next contract occurs at 2003-12-11 | 2014-04-21 18:45:45 Date rule based rollover from ESH04 to next contract occurs at 2004-03-11 | 2014-04-21 18:45:45 Date rule based rollover from ESM04 to next contract occurs at 2004-06-10 | 2014-04-21 18:45:45 Date rule based rollover from ESU04 to next contract occurs at 2004-09-09 | 2014-04-21 18:45:45 Date rule based rollover from ESZ04 to next contract occurs at 2004-12-09 | 2014-04-21 18:45:45 Date rule based rollover from ESH05 to next contract occurs at 2005-03-10 | 2014-04-21 18:45:45 Date rule based rollover from ESM05 to next contract occurs at 2005-06-09 | 2014-04-21 18:45:45 Date rule based rollover from ESU05 to next contract occurs at 2005-09-08 | 2014-04-21 18:45:45 Date rule based rollover from ESZ05 to next contract occurs at 2005-12-08 | 2014-04-21 18:45:45 Date rule based rollover from ESH06 to next contract occurs at 2006-03-09 | 2014-04-21 18:45:45 Date rule based rollover from ESM06 to next contract occurs at 2006-06-08 | 2014-04-21 18:45:45 Date rule based rollover from ESU06 to next contract occurs at 2006-09-07 | 2014-04-21 18:45:45 Date rule based rollover from ESZ06 to next contract occurs at 2006-12-07 | 2014-04-21 18:45:45 Date rule based rollover from ESH07 to next contract occurs at 2007-03-08 | 2014-04-21 18:45:45 Date rule based rollover from ESM07 to next contract occurs at 2007-06-07 | 2014-04-21 18:45:45 Date rule based rollover from ESU07 to next contract occurs at 2007-09-13 | 2014-04-21 18:45:45 Date rule based rollover from ESZ07 to next contract occurs at 2007-12-13 | 2014-04-21 18:45:45 Date rule based rollover from ESH08 to next contract occurs at 2008-03-13 | 2014-04-21 18:45:45 Date rule based rollover from ESM08 to next contract occurs at 2008-06-12 | 2014-04-21 18:45:45 Date rule based rollover from ESU08 to next contract occurs at 2008-09-11 | 2014-04-21 18:45:45 Date rule based rollover from ESZ08 to next contract occurs at 2008-12-11 | 2014-04-21 18:45:45 Date rule based rollover from ESH09 to next contract occurs at 2009-03-12 | 2014-04-21 18:45:45 Date rule based rollover from ESM09 to next contract occurs at 2009-06-11 | 2014-04-21 18:45:45 Date rule based rollover from ESU09 to next contract occurs at 2009-09-10 | 2014-04-21 18:45:45 Date rule based rollover from ESZ09 to next contract occurs at 2009-12-10 | 2014-04-21 18:45:45 Date rule based rollover from ESH10 to next contract occurs at 2010-03-11 | 2014-04-21 18:45:45 Date rule based rollover from ESM10 to next contract occurs at 2010-06-10 | 2014-04-21 18:45:45 Date rule based rollover from ESU10 to next contract occurs at 2010-09-09 | 2014-04-21 18:45:45 Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09 | 2014-04-21 18:45:45 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10 | 2014-04-21 18:45:45 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-04-21 18:45:45 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-04-21 18:45:45 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-04-21 18:45:45 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-04-21 18:45:45 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-04-21 18:45:45 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-04-21 18:45:45 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-04-21 18:45:45 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-04-21 18:45:45 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-04-21 18:45:45 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-04-21 18:45:45 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-04-21 18:45:45 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-04-21 18:45:45 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM02 for the date range from 2002-03-07 to 2002-06-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU02 for the date range from 2002-06-13 to 2002-09-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ02 for the date range from 2002-09-12 to 2002-12-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH03 for the date range from 2002-12-12 to 2003-03-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM03 for the date range from 2003-03-13 to 2003-06-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU03 for the date range from 2003-06-12 to 2003-09-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ03 for the date range from 2003-09-11 to 2003-12-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH04 for the date range from 2003-12-11 to 2004-03-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM04 for the date range from 2004-03-11 to 2004-06-05 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU04 for the date range from 2004-06-10 to 2004-09-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ04 for the date range from 2004-09-09 to 2004-12-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH05 for the date range from 2004-12-09 to 2005-03-05 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM05 for the date range from 2005-03-10 to 2005-06-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU05 for the date range from 2005-06-09 to 2005-09-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ05 for the date range from 2005-09-08 to 2005-12-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH06 for the date range from 2005-12-08 to 2006-03-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM06 for the date range from 2006-03-09 to 2006-06-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU06 for the date range from 2006-06-08 to 2006-09-02 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ06 for the date range from 2006-09-07 to 2006-12-02 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH07 for the date range from 2006-12-07 to 2007-03-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM07 for the date range from 2007-03-08 to 2007-06-02 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU07 for the date range from 2007-06-07 to 2007-09-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ07 for the date range from 2007-09-13 to 2007-12-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH08 for the date range from 2007-12-13 to 2008-03-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM08 for the date range from 2008-03-13 to 2008-06-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU08 for the date range from 2008-06-12 to 2008-09-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ08 for the date range from 2008-09-11 to 2008-12-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH09 for the date range from 2008-12-11 to 2009-03-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM09 for the date range from 2009-03-12 to 2009-06-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU09 for the date range from 2009-06-11 to 2009-09-05 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-05 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-06 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-05 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-05 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-04-21 18:45:45 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:45 Symbols used for ESM14 continuous contract chart: | 2014-04-21 18:45:45 ESM02 | 2014-04-21 18:45:45 ESU02 | 2014-04-21 18:45:45 ESZ02 | 2014-04-21 18:45:45 ESH03 | 2014-04-21 18:45:45 ESM03 | 2014-04-21 18:45:45 ESU03 | 2014-04-21 18:45:45 ESZ03 | 2014-04-21 18:45:45 ESH04 | 2014-04-21 18:45:45 ESM04 | 2014-04-21 18:45:45 ESU04 | 2014-04-21 18:45:45 ESZ04 | 2014-04-21 18:45:45 ESH05 | 2014-04-21 18:45:45 ESM05 | 2014-04-21 18:45:45 ESU05 | 2014-04-21 18:45:45 ESZ05 | 2014-04-21 18:45:45 ESH06 | 2014-04-21 18:45:45 ESM06 | 2014-04-21 18:45:45 ESU06 | 2014-04-21 18:45:45 ESZ06 | 2014-04-21 18:45:45 ESH07 | 2014-04-21 18:45:45 ESM07 | 2014-04-21 18:45:45 ESU07 | 2014-04-21 18:45:45 ESZ07 | 2014-04-21 18:45:45 ESH08 | 2014-04-21 18:45:45 ESM08 | 2014-04-21 18:45:45 ESU08 | 2014-04-21 18:45:45 ESZ08 | 2014-04-21 18:45:45 ESH09 | 2014-04-21 18:45:45 ESM09 | 2014-04-21 18:45:45 ESU09 | 2014-04-21 18:45:45 ESZ09 | 2014-04-21 18:45:45 ESH10 | 2014-04-21 18:45:45 ESM10 | 2014-04-21 18:45:45 ESU10 | 2014-04-21 18:45:45 ESZ10 | 2014-04-21 18:45:45 ESH11 | 2014-04-21 18:45:45 ESM11 | 2014-04-21 18:45:45 ESU11 | 2014-04-21 18:45:45 ESZ11 | 2014-04-21 18:45:45 ESH12 | 2014-04-21 18:45:45 ESM12 | 2014-04-21 18:45:45 ESU12 | 2014-04-21 18:45:45 ESZ12 | 2014-04-21 18:45:45 ESH13 | 2014-04-21 18:45:45 ESM13 | 2014-04-21 18:45:45 ESU13 | 2014-04-21 18:45:45 ESZ13 | 2014-04-21 18:45:45 ESH14 | 2014-04-21 18:45:45 ESM14 | 2014-04-21 18:45:45 Volume based rollover from ESM02 to ESU02 occurs at 2002-06-13 | 2014-04-21 18:45:45 Volume based rollover from ESU02 to ESZ02 occurs at 2002-09-12 | 2014-04-21 18:45:45 Volume based rollover from ESZ02 to ESH03 occurs at 2002-12-12 | 2014-04-21 18:45:45 Volume based rollover from ESH03 to ESM03 occurs at 2003-03-13 | 2014-04-21 18:45:45 Volume based rollover from ESM03 to ESU03 occurs at 2003-06-12 | 2014-04-21 18:45:45 Volume based rollover from ESU03 to ESZ03 occurs at 2003-09-11 | 2014-04-21 18:45:45 Volume based rollover from ESZ03 to ESH04 occurs at 2003-12-11 | 2014-04-21 18:45:45 Volume based rollover from ESH04 to ESM04 occurs at 2004-03-11 | 2014-04-21 18:45:45 Volume based rollover from ESM04 to ESU04 occurs at 2004-06-14 | 2014-04-21 18:45:45 Volume based rollover from ESU04 to ESZ04 occurs at 2004-09-09 | 2014-04-21 18:45:45 Volume based rollover from ESZ04 to ESH05 occurs at 2004-12-09 | 2014-04-21 18:45:45 Volume based rollover from ESH05 to ESM05 occurs at 2005-03-10 | 2014-04-21 18:45:45 Volume based rollover from ESM05 to ESU05 occurs at 2005-06-09 | 2014-04-21 18:45:45 Volume based rollover from ESU05 to ESZ05 occurs at 2005-09-08 | 2014-04-21 18:45:45 Volume based rollover from ESZ05 to ESH06 occurs at 2005-12-08 | 2014-04-21 18:45:45 Volume based rollover from ESH06 to ESM06 occurs at 2006-03-09 | 2014-04-21 18:45:45 Volume based rollover from ESM06 to ESU06 occurs at 2006-06-08 | 2014-04-21 18:45:45 Volume based rollover from ESU06 to ESZ06 occurs at 2006-09-07 | 2014-04-21 18:45:45 Volume based rollover from ESZ06 to ESH07 occurs at 2006-12-07 | 2014-04-21 18:45:45 Volume based rollover from ESH07 to ESM07 occurs at 2007-03-08 | 2014-04-21 18:45:45 Volume based rollover from ESM07 to ESU07 occurs at 2007-06-07 | 2014-04-21 18:45:45 Volume based rollover from ESU07 to ESZ07 occurs at 2007-09-13 | 2014-04-21 18:45:45 Volume based rollover from ESZ07 to ESH08 occurs at 2007-12-13 | 2014-04-21 18:45:45 Volume based rollover from ESH08 to ESM08 occurs at 2008-03-13 | 2014-04-21 18:45:45 Volume based rollover from ESM08 to ESU08 occurs at 2008-06-12 | 2014-04-21 18:45:45 Volume based rollover from ESU08 to ESZ08 occurs at 2008-09-11 | 2014-04-21 18:45:45 Volume based rollover from ESZ08 to ESH09 occurs at 2008-12-11 | 2014-04-21 18:45:45 Volume based rollover from ESH09 to ESM09 occurs at 2009-03-12 | 2014-04-21 18:45:45 Volume based rollover from ESM09 to ESU09 occurs at 2009-06-11 | 2014-04-21 18:45:45 Volume based rollover from ESU09 to ESZ09 occurs at 2009-09-10 | 2014-04-21 18:45:45 Volume based rollover from ESZ09 to ESH10 occurs at 2009-12-11 | 2014-04-21 18:45:45 Volume based rollover from ESH10 to ESM10 occurs at 2010-03-12 | 2014-04-21 18:45:45 Volume based rollover from ESM10 to ESU10 occurs at 2010-06-11 | 2014-04-21 18:45:45 Volume based rollover from ESU10 to ESZ10 occurs at 2010-09-10 | 2014-04-21 18:45:45 Volume based rollover from ESZ10 to ESH11 occurs at 2010-12-10 | 2014-04-21 18:45:45 Volume based rollover from ESH11 to ESM11 occurs at 2011-03-11 | 2014-04-21 18:45:45 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-04-21 18:45:45 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-04-21 18:45:45 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-04-21 18:45:45 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-04-21 18:45:45 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-04-21 18:45:45 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-04-21 18:45:45 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-04-21 18:45:45 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-04-21 18:45:45 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-04-21 18:45:45 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-04-21 18:45:45 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-04-21 18:45:45 Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Performing continuous futures contract back adjustment calculations. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM02 Open price on 2002-06-13 is 1020. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU02 Open price on 2002-06-13 is 1024. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM02 price difference to ESU02 is 4. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU02 Open price on 2002-09-12 is 906.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ02 Open price on 2002-09-12 is 906.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU02 price difference to ESZ02 is 0. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ02 Open price on 2002-12-12 is 902.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH03 Open price on 2002-12-12 is 901.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ02 price difference to ESH03 is -0.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH03 Open price on 2003-03-13 is 805.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM03 Open price on 2003-03-13 is 804.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH03 price difference to ESM03 is -1.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM03 Open price on 2003-06-12 is 997. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU03 Open price on 2003-06-12 is 996. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM03 price difference to ESU03 is -1. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU03 Open price on 2003-09-11 is 1013.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ03 Open price on 2003-09-11 is 1013.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU03 price difference to ESZ03 is -0.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ03 Open price on 2003-12-11 is 1060.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH04 Open price on 2003-12-11 is 1059.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ03 price difference to ESH04 is -1.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH04 Open price on 2004-03-11 is 1120.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM04 Open price on 2004-03-11 is 1119.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH04 price difference to ESM04 is -0.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM04 Open price on 2004-06-14 is 1134.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU04 Open price on 2004-06-14 is 1133.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM04 price difference to ESU04 is -1. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU04 Open price on 2004-09-09 is 1118.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ04 Open price on 2004-09-09 is 1119. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU04 price difference to ESZ04 is 0.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ04 Open price on 2004-12-09 is 1183.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH05 Open price on 2004-12-09 is 1185.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ04 price difference to ESH05 is 2. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH05 Open price on 2005-03-10 is 1206.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM05 Open price on 2005-03-10 is 1211.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH05 price difference to ESM05 is 5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM05 Open price on 2005-06-09 is 1195.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU05 Open price on 2005-06-09 is 1200.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM05 price difference to ESU05 is 5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU05 Open price on 2005-09-08 is 1235.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ05 Open price on 2005-09-08 is 1241.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU05 price difference to ESZ05 is 6.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ05 Open price on 2005-12-08 is 1257.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH06 Open price on 2005-12-08 is 1265.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ05 price difference to ESH06 is 7.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH06 Open price on 2006-03-09 is 1279.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM06 Open price on 2006-03-09 is 1290. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH06 price difference to ESM06 is 10.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM06 Open price on 2006-06-08 is 1256.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU06 Open price on 2006-06-08 is 1267. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM06 price difference to ESU06 is 10.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU06 Open price on 2006-09-07 is 1302.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ06 Open price on 2006-09-07 is 1313.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU06 price difference to ESZ06 is 11.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ06 Open price on 2006-12-07 is 1414.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH07 Open price on 2006-12-07 is 1426.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ06 price difference to ESH07 is 12. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH07 Open price on 2007-03-08 is 1392.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM07 Open price on 2007-03-08 is 1404.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH07 price difference to ESM07 is 11.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM07 Open price on 2007-06-07 is 1516.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU07 Open price on 2007-06-07 is 1532. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM07 price difference to ESU07 is 15.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU07 Open price on 2007-09-13 is 1475.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ07 Open price on 2007-09-13 is 1488.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU07 price difference to ESZ07 is 12.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ07 Open price on 2007-12-13 is 1490. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH08 Open price on 2007-12-13 is 1500.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ07 price difference to ESH08 is 10.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH08 Open price on 2008-03-13 is 1310. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM08 Open price on 2008-03-13 is 1312.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH08 price difference to ESM08 is 2.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM08 Open price on 2008-06-12 is 1335.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU08 Open price on 2008-06-12 is 1337. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM08 price difference to ESU08 is 1.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU08 Open price on 2008-09-11 is 1232.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ08 Open price on 2008-09-11 is 1234. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU08 price difference to ESZ08 is 1.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ08 Open price on 2008-12-11 is 898.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH09 Open price on 2008-12-11 is 899.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ08 price difference to ESH09 is 1.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH09 Open price on 2009-03-12 is 721.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM09 Open price on 2009-03-12 is 717.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH09 price difference to ESM09 is -3.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM09 Open price on 2009-06-11 is 939.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU09 Open price on 2009-06-11 is 936. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM09 price difference to ESU09 is -3.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU09 Open price on 2009-09-10 is 1032.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ09 Open price on 2009-09-10 is 1028. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU09 price difference to ESZ09 is -4.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ09 Open price on 2009-12-11 is 1102.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH10 Open price on 2009-12-11 is 1097.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ09 price difference to ESH10 is -4.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH10 Open price on 2010-03-12 is 1150.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM10 Open price on 2010-03-12 is 1146. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH10 price difference to ESM10 is -4.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM10 Open price on 2010-06-11 is 1084. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU10 Open price on 2010-06-11 is 1079.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM10 price difference to ESU10 is -4.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU10 Open price on 2010-09-10 is 1103. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ10 Open price on 2010-09-10 is 1097.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU10 price difference to ESZ10 is -5.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ10 Open price on 2010-12-10 is 1232.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH11 Open price on 2010-12-10 is 1227.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ10 price difference to ESH11 is -5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH11 Open price on 2011-03-11 is 1293.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM11 Open price on 2011-03-11 is 1289. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH11 price difference to ESM11 is -4.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM11 Open price on 2011-06-10 is 1287.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU11 Open price on 2011-06-10 is 1282.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM11 price difference to ESU11 is -5.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU11 Open price on 2011-09-09 is 1185.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ11 Open price on 2011-09-09 is 1180. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU11 price difference to ESZ11 is -5.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ11 Open price on 2011-12-09 is 1235.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH12 Open price on 2011-12-09 is 1229.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ11 price difference to ESH12 is -5.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH12 Open price on 2012-03-09 is 1366.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM12 Open price on 2012-03-09 is 1360.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH12 price difference to ESM12 is -6. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM12 Open price on 2012-06-08 is 1316.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU12 Open price on 2012-06-08 is 1309.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM12 price difference to ESU12 is -6.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU12 Open price on 2012-09-14 is 1456.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ12 Open price on 2012-09-14 is 1450. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU12 price difference to ESZ12 is -6.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ12 Open price on 2012-12-14 is 1416.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH13 Open price on 2012-12-14 is 1410.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ12 price difference to ESH13 is -6.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH13 Open price on 2013-03-08 is 1542.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM13 Open price on 2013-03-08 is 1538. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH13 price difference to ESM13 is -4.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM13 Open price on 2013-06-14 is 1637.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU13 Open price on 2013-06-14 is 1631.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM13 price difference to ESU13 is -6.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU13 Open price on 2013-09-13 is 1684.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ13 Open price on 2013-09-13 is 1678.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESU13 price difference to ESZ13 is -6.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ13 Open price on 2013-12-13 is 1773.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH14 Open price on 2013-12-13 is 1767. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESZ13 price difference to ESH14 is -6.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH14 Open price on 2014-03-14 is 1847.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESM14 Open price on 2014-03-14 is 1840. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: ESH14 price difference to ESM14 is -7.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM02 is 11. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU02 is 7. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ02 is 7. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH03 is 7.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM03 is 8.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU03 is 9.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ03 is 10. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH04 is 11.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM04 is 12. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU04 is 13. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ04 is 12.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH05 is 10.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM05 is 5.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU05 is 0.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ05 is -6. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH06 is -13.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM06 is -24. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU06 is -34.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ06 is -45.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH07 is -57.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM07 is -69.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU07 is -84.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ07 is -97. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH08 is -107.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM08 is -109.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU08 is -111.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ08 is -113.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH09 is -114.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM09 is -110.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU09 is -107. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ09 is -102.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH10 is -97.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM10 is -93. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU10 is -88.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ10 is -83.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH11 is -78.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM11 is -73.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU11 is -68.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ11 is -62.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH12 is -56.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM12 is -50.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU12 is -44. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ12 is -37.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH13 is -31.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESM13 is -26.5. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESU13 is -20.25. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESZ13 is -13.75. | 2014-04-21 18:45:45 ESM14/F.US.EPM14 [CBV] Daily #4: Back adjust amount for symbol ESH14 is -7.25. | 2014-04-21 18:45:45 Date rule based rollover from F.US.EPH14 to next contract occurs at 2014-03-13 | 2014-04-21 18:45:46 Date rule based rollover from F.US.EPM14 to next contract occurs at 2014-06-12 | 2014-04-21 18:45:46 Checking Intraday data file for symbol F.US.EPH14 for the date range from 2013-12-12 to 2014-03-13 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-04-21 18:45:46 Checking Intraday data file for symbol F.US.EPM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:46 Symbols used for F.US.EPM14 continuous contract chart: | 2014-04-21 18:45:46 F.US.EPH14 | 2014-04-21 18:45:46 F.US.EPM14 | 2014-04-21 18:45:46 Volume based rollover from F.US.EPH14 to F.US.EPM14 occurs at 2014-03-14 | 2014-04-21 18:45:46 F.US.EPM14 [CBV] 10 Min #5: Performing continuous futures contract back adjustment calculations. | 2014-04-21 18:45:46 F.US.EPM14 [CBV] 10 Min #5: F.US.EPH14 Open price on 2014-03-14 is 1847.25. | 2014-04-21 18:45:46 F.US.EPM14 [CBV] 10 Min #5: F.US.EPM14 Open price on 2014-03-14 is 1840. | 2014-04-21 18:45:46 F.US.EPM14 [CBV] 10 Min #5: F.US.EPH14 price difference to F.US.EPM14 is -7.25. | 2014-04-21 18:45:46 F.US.EPM14 [CBV] 10 Min #5: Back adjust amount for symbol F.US.EPH14 is -7.25. | 2014-04-21 18:45:46 Mapping F.US.EPM14 to ESM4. Service code: cme | 2014-04-21 18:45:46 SC Exchange Data - Starting real-time market data updates for: ESM4 | 2014-04-21 18:45:46 Using username 0 | 2014-04-21 18:45:46 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-04-21 18:45:46 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-04-21 18:45:46 HD Request # 2 - Downloading Intraday chart data for F.US.EPM14 to the file F.US.EPM14.scid. Service: cme | 2014-04-21 18:45:46 HD Request # 2 - Download start Date-Time: 2014-04-21 13:04:54.0 | 2014-04-21 18:45:46 HD Request # 2 - Using server: scdf2.sierracharts.com port 10149 | 2014-04-21 18:45:46 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-04-21 18:45:46 HD Request # 3 - Downloading Historical Daily chart data for ESM14. Starting date: 2014-04-17. Service: cqg | 2014-04-21 18:45:46 HD Request # 3 - Using user Barchart Historical data account. | 2014-04-21 18:45:46 HD Request # 3 - Requesting historical Daily data for ESM14 starting at 2014-04-16 | 2014-04-21 18:45:46 The network socket is connected. | 2014-04-21 18:45:46 SC Exchange Data: Connected to server. | 2014-04-21 18:45:46 SC Exchange Data: Sending logon request message. | 2014-04-21 18:45:46 The network socket is connected. | 2014-04-21 18:45:46 HD Request # 2 - Sending historical data logon request message. | 2014-04-21 18:45:46 HD Request # 3 - Receiving historical Daily data for ESM14 starting at 2014-04-16 | 2014-04-21 18:45:46 Writing historical Daily data for ESM14 to the file ESM14.dly | 2014-04-21 18:45:46 HD Request # 3 - Received 4 records from 2014-04-16 00:00:00 to 2014-04-22 00:00:00 (7.0 days) and wrote 3 records for ESM14 | 2014-04-21 18:45:46 HD Request # 3 - Daily download COMPLETE for ESM14 | 2014-04-21 18:45:46 Date rule based rollover from ESM02 to next contract occurs at 2002-06-13 | 2014-04-21 18:45:46 Date rule based rollover from ESU02 to next contract occurs at 2002-09-12 | 2014-04-21 18:45:46 Date rule based rollover from ESZ02 to next contract occurs at 2002-12-12 | 2014-04-21 18:45:46 Date rule based rollover from ESH03 to next contract occurs at 2003-03-13 | 2014-04-21 18:45:46 Date rule based rollover from ESM03 to next contract occurs at 2003-06-12 | 2014-04-21 18:45:46 Date rule based rollover from ESU03 to next contract occurs at 2003-09-11 | 2014-04-21 18:45:46 Date rule based rollover from ESZ03 to next contract occurs at 2003-12-11 | 2014-04-21 18:45:46 Date rule based rollover from ESH04 to next contract occurs at 2004-03-11 | 2014-04-21 18:45:46 Date rule based rollover from ESM04 to next contract occurs at 2004-06-10 | 2014-04-21 18:45:46 Date rule based rollover from ESU04 to next contract occurs at 2004-09-09 | 2014-04-21 18:45:46 Date rule based rollover from ESZ04 to next contract occurs at 2004-12-09 | 2014-04-21 18:45:46 Date rule based rollover from ESH05 to next contract occurs at 2005-03-10 | 2014-04-21 18:45:46 Date rule based rollover from ESM05 to next contract occurs at 2005-06-09 | 2014-04-21 18:45:46 Date rule based rollover from ESU05 to next contract occurs at 2005-09-08 | 2014-04-21 18:45:46 Date rule based rollover from ESZ05 to next contract occurs at 2005-12-08 | 2014-04-21 18:45:46 Date rule based rollover from ESH06 to next contract occurs at 2006-03-09 | 2014-04-21 18:45:46 Date rule based rollover from ESM06 to next contract occurs at 2006-06-08 | 2014-04-21 18:45:46 Date rule based rollover from ESU06 to next contract occurs at 2006-09-07 | 2014-04-21 18:45:46 Date rule based rollover from ESZ06 to next contract occurs at 2006-12-07 | 2014-04-21 18:45:46 Date rule based rollover from ESH07 to next contract occurs at 2007-03-08 | 2014-04-21 18:45:46 Date rule based rollover from ESM07 to next contract occurs at 2007-06-07 | 2014-04-21 18:45:46 Date rule based rollover from ESU07 to next contract occurs at 2007-09-13 | 2014-04-21 18:45:46 Date rule based rollover from ESZ07 to next contract occurs at 2007-12-13 | 2014-04-21 18:45:46 Date rule based rollover from ESH08 to next contract occurs at 2008-03-13 | 2014-04-21 18:45:46 Date rule based rollover from ESM08 to next contract occurs at 2008-06-12 | 2014-04-21 18:45:46 Date rule based rollover from ESU08 to next contract occurs at 2008-09-11 | 2014-04-21 18:45:46 Date rule based rollover from ESZ08 to next contract occurs at 2008-12-11 | 2014-04-21 18:45:46 Date rule based rollover from ESH09 to next contract occurs at 2009-03-12 | 2014-04-21 18:45:46 Date rule based rollover from ESM09 to next contract occurs at 2009-06-11 | 2014-04-21 18:45:46 Date rule based rollover from ESU09 to next contract occurs at 2009-09-10 | 2014-04-21 18:45:46 Date rule based rollover from ESZ09 to next contract occurs at 2009-12-10 | 2014-04-21 18:45:46 Date rule based rollover from ESH10 to next contract occurs at 2010-03-11 | 2014-04-21 18:45:46 Date rule based rollover from ESM10 to next contract occurs at 2010-06-10 | 2014-04-21 18:45:46 Date rule based rollover from ESU10 to next contract occurs at 2010-09-09 | 2014-04-21 18:45:46 Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09 | 2014-04-21 18:45:46 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10 | 2014-04-21 18:45:46 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-04-21 18:45:46 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-04-21 18:45:46 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-04-21 18:45:46 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-04-21 18:45:46 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-04-21 18:45:46 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-04-21 18:45:46 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-04-21 18:45:46 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-04-21 18:45:46 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-04-21 18:45:46 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-04-21 18:45:46 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-04-21 18:45:46 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-04-21 18:45:46 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM02 for the date range from 2002-03-07 to 2002-06-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU02 for the date range from 2002-06-13 to 2002-09-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ02 for the date range from 2002-09-12 to 2002-12-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH03 for the date range from 2002-12-12 to 2003-03-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM03 for the date range from 2003-03-13 to 2003-06-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU03 for the date range from 2003-06-12 to 2003-09-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ03 for the date range from 2003-09-11 to 2003-12-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH04 for the date range from 2003-12-11 to 2004-03-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM04 for the date range from 2004-03-11 to 2004-06-05 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU04 for the date range from 2004-06-10 to 2004-09-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ04 for the date range from 2004-09-09 to 2004-12-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH05 for the date range from 2004-12-09 to 2005-03-05 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM05 for the date range from 2005-03-10 to 2005-06-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU05 for the date range from 2005-06-09 to 2005-09-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ05 for the date range from 2005-09-08 to 2005-12-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH06 for the date range from 2005-12-08 to 2006-03-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM06 for the date range from 2006-03-09 to 2006-06-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU06 for the date range from 2006-06-08 to 2006-09-02 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ06 for the date range from 2006-09-07 to 2006-12-02 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH07 for the date range from 2006-12-07 to 2007-03-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM07 for the date range from 2007-03-08 to 2007-06-02 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU07 for the date range from 2007-06-07 to 2007-09-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ07 for the date range from 2007-09-13 to 2007-12-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH08 for the date range from 2007-12-13 to 2008-03-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM08 for the date range from 2008-03-13 to 2008-06-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU08 for the date range from 2008-06-12 to 2008-09-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ08 for the date range from 2008-09-11 to 2008-12-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH09 for the date range from 2008-12-11 to 2009-03-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM09 for the date range from 2009-03-12 to 2009-06-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU09 for the date range from 2009-06-11 to 2009-09-05 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-05 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-06 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-05 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-05 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-04-21 18:45:46 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-04-21 18:45:46 Symbols used for ESM14 continuous contract chart: | 2014-04-21 18:45:46 ESM02 | 2014-04-21 18:45:46 ESU02 | 2014-04-21 18:45:46 ESZ02 | 2014-04-21 18:45:46 ESH03 | 2014-04-21 18:45:46 ESM03 | 2014-04-21 18:45:46 ESU03 | 2014-04-21 18:45:46 ESZ03 | 2014-04-21 18:45:46 ESH04 | 2014-04-21 18:45:46 ESM04 | 2014-04-21 18:45:46 ESU04 | 2014-04-21 18:45:46 ESZ04 | 2014-04-21 18:45:46 ESH05 | 2014-04-21 18:45:46 ESM05 | 2014-04-21 18:45:46 ESU05 | 2014-04-21 18:45:46 ESZ05 | 2014-04-21 18:45:46 ESH06 | 2014-04-21 18:45:46 ESM06 | 2014-04-21 18:45:46 ESU06 | 2014-04-21 18:45:46 ESZ06 | 2014-04-21 18:45:46 ESH07 | 2014-04-21 18:45:46 ESM07 | 2014-04-21 18:45:46 ESU07 | 2014-04-21 18:45:46 ESZ07 | 2014-04-21 18:45:46 ESH08 | 2014-04-21 18:45:46 ESM08 | 2014-04-21 18:45:46 ESU08 | 2014-04-21 18:45:46 ESZ08 | 2014-04-21 18:45:46 ESH09 | 2014-04-21 18:45:46 ESM09 | 2014-04-21 18:45:46 ESU09 | 2014-04-21 18:45:46 ESZ09 | 2014-04-21 18:45:46 ESH10 | 2014-04-21 18:45:46 ESM10 | 2014-04-21 18:45:46 ESU10 | 2014-04-21 18:45:46 ESZ10 | 2014-04-21 18:45:46 ESH11 | 2014-04-21 18:45:46 ESM11 | 2014-04-21 18:45:46 ESU11 | 2014-04-21 18:45:46 ESZ11 | 2014-04-21 18:45:46 ESH12 | 2014-04-21 18:45:46 ESM12 | 2014-04-21 18:45:46 ESU12 | 2014-04-21 18:45:46 ESZ12 | 2014-04-21 18:45:46 ESH13 | 2014-04-21 18:45:46 ESM13 | 2014-04-21 18:45:46 ESU13 | 2014-04-21 18:45:46 ESZ13 | 2014-04-21 18:45:46 ESH14 | 2014-04-21 18:45:46 ESM14 | 2014-04-21 18:45:46 ESM14/F.US.EPM14 [CBV] [M] Daily #4: Download is complete for all contract months in chart. Proceeding with data load. | 2014-04-21 18:45:47 Volume based rollover from ESM02 to ESU02 occurs at 2002-06-13 | 2014-04-21 18:45:47 Volume based rollover from ESU02 to ESZ02 occurs at 2002-09-12 | 2014-04-21 18:45:47 Volume based rollover from ESZ02 to ESH03 occurs at 2002-12-12 | 2014-04-21 18:45:47 Volume based rollover from ESH03 to ESM03 occurs at 2003-03-13 | 2014-04-21 18:45:47 Volume based rollover from ESM03 to ESU03 occurs at 2003-06-12 | 2014-04-21 18:45:47 Volume based rollover from ESU03 to ESZ03 occurs at 2003-09-11 | 2014-04-21 18:45:47 Volume based rollover from ESZ03 to ESH04 occurs at 2003-12-11 | 2014-04-21 18:45:47 Volume based rollover from ESH04 to ESM04 occurs at 2004-03-11 | 2014-04-21 18:45:47 Volume based rollover from ESM04 to ESU04 occurs at 2004-06-14 | 2014-04-21 18:45:47 Volume based rollover from ESU04 to ESZ04 occurs at 2004-09-09 | 2014-04-21 18:45:47 Volume based rollover from ESZ04 to ESH05 occurs at 2004-12-09 | 2014-04-21 18:45:47 Volume based rollover from ESH05 to ESM05 occurs at 2005-03-10 | 2014-04-21 18:45:47 Volume based rollover from ESM05 to ESU05 occurs at 2005-06-09 | 2014-04-21 18:45:47 Volume based rollover from ESU05 to ESZ05 occurs at 2005-09-08 | 2014-04-21 18:45:47 Volume based rollover from ESZ05 to ESH06 occurs at 2005-12-08 | 2014-04-21 18:45:47 Volume based rollover from ESH06 to ESM06 occurs at 2006-03-09 | 2014-04-21 18:45:47 Volume based rollover from ESM06 to ESU06 occurs at 2006-06-08 | 2014-04-21 18:45:47 Volume based rollover from ESU06 to ESZ06 occurs at 2006-09-07 | 2014-04-21 18:45:47 Volume based rollover from ESZ06 to ESH07 occurs at 2006-12-07 | 2014-04-21 18:45:47 Volume based rollover from ESH07 to ESM07 occurs at 2007-03-08 | 2014-04-21 18:45:47 Volume based rollover from ESM07 to ESU07 occurs at 2007-06-07 | 2014-04-21 18:45:47 Volume based rollover from ESU07 to ESZ07 occurs at 2007-09-13 | 2014-04-21 18:45:47 Volume based rollover from ESZ07 to ESH08 occurs at 2007-12-13 | 2014-04-21 18:45:47 Volume based rollover from ESH08 to ESM08 occurs at 2008-03-13 | 2014-04-21 18:45:47 Volume based rollover from ESM08 to ESU08 occurs at 2008-06-12 | 2014-04-21 18:45:47 Volume based rollover from ESU08 to ESZ08 occurs at 2008-09-11 | 2014-04-21 18:45:47 Volume based rollover from ESZ08 to ESH09 occurs at 2008-12-11 | 2014-04-21 18:45:47 Volume based rollover from ESH09 to ESM09 occurs at 2009-03-12 | 2014-04-21 18:45:47 Volume based rollover from ESM09 to ESU09 occurs at 2009-06-11 | 2014-04-21 18:45:47 Volume based rollover from ESU09 to ESZ09 occurs at 2009-09-10 | 2014-04-21 18:45:47 Volume based rollover from ESZ09 to ESH10 occurs at 2009-12-11 | 2014-04-21 18:45:47 Volume based rollover from ESH10 to ESM10 occurs at 2010-03-12 | 2014-04-21 18:45:47 Volume based rollover from ESM10 to ESU10 occurs at 2010-06-11 | 2014-04-21 18:45:47 Volume based rollover from ESU10 to ESZ10 occurs at 2010-09-10 | 2014-04-21 18:45:47 Volume based rollover from ESZ10 to ESH11 occurs at 2010-12-10 | 2014-04-21 18:45:47 Volume based rollover from ESH11 to ESM11 occurs at 2011-03-11 | 2014-04-21 18:45:47 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-04-21 18:45:47 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-04-21 18:45:47 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-04-21 18:45:47 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-04-21 18:45:47 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-04-21 18:45:47 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-04-21 18:45:47 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-04-21 18:45:47 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-04-21 18:45:47 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-04-21 18:45:47 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-04-21 18:45:47 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-04-21 18:45:47 Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: Performing continuous futures contract back adjustment calculations. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM02 Open price on 2002-06-13 is 1020. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU02 Open price on 2002-06-13 is 1024. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM02 price difference to ESU02 is 4. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU02 Open price on 2002-09-12 is 906.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ02 Open price on 2002-09-12 is 906.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU02 price difference to ESZ02 is 0. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ02 Open price on 2002-12-12 is 902.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH03 Open price on 2002-12-12 is 901.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ02 price difference to ESH03 is -0.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH03 Open price on 2003-03-13 is 805.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM03 Open price on 2003-03-13 is 804.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH03 price difference to ESM03 is -1.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM03 Open price on 2003-06-12 is 997. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU03 Open price on 2003-06-12 is 996. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM03 price difference to ESU03 is -1. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU03 Open price on 2003-09-11 is 1013.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ03 Open price on 2003-09-11 is 1013.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU03 price difference to ESZ03 is -0.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ03 Open price on 2003-12-11 is 1060.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH04 Open price on 2003-12-11 is 1059.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ03 price difference to ESH04 is -1.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH04 Open price on 2004-03-11 is 1120.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM04 Open price on 2004-03-11 is 1119.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH04 price difference to ESM04 is -0.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM04 Open price on 2004-06-14 is 1134.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU04 Open price on 2004-06-14 is 1133.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM04 price difference to ESU04 is -1. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU04 Open price on 2004-09-09 is 1118.25. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ04 Open price on 2004-09-09 is 1119. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESU04 price difference to ESZ04 is 0.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ04 Open price on 2004-12-09 is 1183.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH05 Open price on 2004-12-09 is 1185.5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESZ04 price difference to ESH05 is 2. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH05 Open price on 2005-03-10 is 1206.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM05 Open price on 2005-03-10 is 1211.75. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESH05 price difference to ESM05 is 5. | 2014-04-21 18:45:47 ESM14/F.US.EPM14 [CBV] [M] Daily #4: ESM05 Open price on 2005-06-09 is 1195.75. | 2014-04-21 |
[2014-04-22 03:48:02] |
User12676 - Posts: 70 |
Sorry, just pasting relevant part now F.US.TYAN14 [CBV] [M] Delta 6000v #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-04-21 20:44:35 Volume based rollover from F.US.TYAH14 to F.US.TYAN14 occurs at 2014-03-20 | 2014-04-21 20:44:35 F.US.TYAN14 [CBV] [M] Delta 6000v #1: Performing continuous futures contract back adjustment calculations. | 2014-04-21 20:44:35 F.US.TYAN14 [CBV] [M] Delta 6000v #1: F.US.TYAH14 Open price on 2014-03-20 is 125.0313. | 2014-04-21 20:44:35 Error while getting daily open price with date 2014-03-23 from file. C:\SierraChart\Data\ZNN14.dly. Error: Encountered end of file. | 2014-04-21 20:44:35 F.US.TYAN14 [CBV] [M] Delta 6000v #1: F.US.TYAH14 price difference to F.US.TYAN14 is 0. | 2014-04-21 20:44:35 F.US.TYAN14 [CBV] [M] Delta 6000v #1: Back adjust amount for symbol F.US.TYAH14 is 0. | 2014-04-21 20:44:35 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.TYAN14.scid | 2014-04-21 20:44:35 |
[2014-04-22 04:08:03] |
Follow through the instructions step-by-step in this section here: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Please take note of the details given. There should not be any missing data as long as you go through a complete re-download procedure for all of the symbols and there is no trouble with downloading the data over your Internet connection. If you still have a problem post a complete image of the chart by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Before posting the image enable Chart >> Show Rollover Dates and make sure the chart is scrolled to the point of the missing data so that we can see it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-22 04:09:07
[2014-04-22 04:10:56] |
Actually we see a problem with this symbol, and we are looking into it now: F.US.TYAN14 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-22 04:14:43] |
Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this go to the F.US.TYAN14 chart and update the symbol to June 2014. The current symbol is not even valid. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-22 05:37:34] |
Thank you
[2014-04-23 20:17:32] |
Still Having Problem with Corn.
screen.jpg / V - Attached On 2014-04-23 20:17:29 UTC - Size: 67.59 KB - 366 views |
[2014-04-23 22:49:38] |
Actually Corn, Soybean and wheat all have this problem now on daily historical. I tried resetting symbols and DDAD. It seems like this problem keeps coming up. Whats going on?
[2014-04-24 00:02:47] |
I think perhaps previously the problem was fixed for intraday, but not historical?
[2014-04-24 00:15:17] |
Perform a Full Reset of the symbol settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps After this reopen new Historical charts for the symbols. We also noticed the Wheat symbol was not correct and it has been changed. Let us know if you still see a problem for any of these symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
