Date/Time: Sat, 01 Mar 2025 02:02:18 +0000
MARKET DEPTH HISTORICAL GRAPH STUDY
View Count: 415
[2021-09-10 17:19:54] |
Enzotrading21 - Posts: 4 |
Hi, After performing the roll over to Z contract my MARKET DEPTH HISTORICAL GRAPH STUDY disappeared from my chart an I can not got it back. I do have, however all the market depth data working on my DOM ladder. Thanks
[2021-09-10 17:42:15] |
John - SC Support - Posts: 38292 |
Most likely this is related to your settings for the Market Depth. In particular, are you using Actual Values for your Color Thresholds? You may have to adjust other settings, depending on the levels of the depth that you are seeing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
