Date/Time: Sat, 01 Mar 2025 02:03:02 +0000
[User Discussion] - study issue
View Count: 606
[2021-09-10 17:10:26] |
User278398 - Posts: 291 |
hello, there is an option to put label above of each bar, that in each label there is information (like: cvd/delta and others)? |
[2021-09-10 17:14:16] |
John - SC Support - Posts: 38292 |
Refer to this study: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-12 07:56:57] |
hello, it is nice to know there is the option to make label that i marked in the attached pic, but i need other label like: cvd,delta,rsi and others...it is possible ? regards. |
[2021-09-12 08:01:20] |
and high minus low (high price -low price) of the bar
[2021-09-12 21:47:41] |
You just need to change the Based On option to change the particular study you want to reference. Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-13 06:41:21] |
very helpful. ...can u tell me how can i get the size of the bar candle (high bar price-low bar price) ? there is a study for this that i can take and use it with BASED ON? regards |
[2021-09-13 14:17:07] |
We would recommend the True Range study. Refer to the information here: True Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
