Date/Time: Sat, 01 Mar 2025 01:52:45 +0000
cant load rithmic data
View Count: 475
[2021-09-10 16:15:42]
User830657 - Posts: 10
hi
I cant load rithmic data . I downloaded DTCbrigde files form your web and this kind of issues I face it . Can You help? Look at screenshot
Best regards
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=54662
[2021-09-10 16:23:28]
John - SC Support - Posts: 38292
We do not recommend using the old bridge files. There is a new interface to Rithmic that you should be using. Follow these Setup Instructions to use the new interface:
Rithmic Trading Platform Service: Setup Instructions
