Date/Time: Tue, 15 Sep 2026 02:35:14 +0000
Connection error: No trade accounts assigned.
View Count: 1630
[2021-09-10 15:21:27]
User248599 - Posts: 3
Can't connect to data feed and get error:
Trading Evaluator - Delayed | Connection error: No trade accounts assigned. | 2021-09-10 11:11:30.042 *
and can not create and commit new account in Trade Account Monitor as:
Not connected to data feed to perform operation. Connect with 'File >> Connect to Data Feed'.
What can be done at this point?
[2021-09-10 15:42:23]
John - SC Support - Posts: 47889
We take it that you are wanting to connect to the Delayed Trading Evaluator service. If that is correct, then do the following:
- Select Global Settings >> Data/Trade Service Settings
- On this window, ensure that the Current Selected Service is set to Trading Evaluator - Delayed.
- Select File >> Disconnect (you may not be able to select this, which is fine).
- Select File Connect to Data Feed.
You will be connected to the Delayed Trading Evaluator service at this point. Then just go through the Setup Instructions starting at Step #6 here:
Simulated Futures Trading Service: Setup Instructions
[2021-09-10 19:02:59]
Trading Evaluator - Delayed worked until today,
now its not working and I followed your advice but no luck
the only what worked in SC Data All Services,
So why SC Data All Services works and Trading Evaluator - Delayed displays error?
Date Time Of Last Edit: 2021-09-10 19:03:16
[2021-09-10 19:14:16]
user_xyz - Posts: 520
I've been trying to setup the Trading Evaluator service (both real-time and the delayed) and getting the same message.
Connection error message from service: Trading Evaluator
If I go past this and start with Step #6 and try to create an account I get this error dialog, "Not connected to data feed to perform operation. Connect with 'File >> Connect to Data"
Date Time Of Last Edit: 2021-09-10 19:15:19
[2021-09-11 19:00:34]
duplanuh - Posts: 8
I have got the same issue. SC Version: 2308
Please give advice to use Trade Evaluator.
Thank you so much.
kind regards,
Laszlo
imagescerror01.PNG / V - Attached On 2021-09-11 19:00:18 UTC - Size: 14.11 KB - 313 views
imagescerror02.PNG / V - Attached On 2021-09-11 19:00:22 UTC - Size: 121.42 KB - 315 views
imagescerror03.PNG / V - Attached On 2021-09-11 19:00:25 UTC - Size: 123.02 KB - 295 views
[2021-09-11 22:41:02]
We are resolving this. Just give us about an hour.
[2021-09-11 22:52:18]
We are resolving this in about 10 minutes. We apologize for the delay.
[2021-09-13 08:48:24]
duplanuh - Posts: 8
It's working. Thank you so much!
