Date/Time: Sat, 01 Mar 2025 01:33:10 +0000
How to save different Data/Trade Service Setting configurations for the same service
View Count: 558
[2021-09-10 15:16:00] |
DabbaDo - Posts: 148 |
I knew how to do this with the old dialog, but I can't get it to work with the new dialog. I want to save two different configurations for Rithmic Direct. When I hit the Save "button" it only saves the current configuration with no ability to name it. Hitting the "Load" button doesn't allow me to choose but only loads the most recent one, I guess. Is this the correct behavior, or am I misunderstanding the dialog? Thanks, Dale Version 2308 |
[2021-09-10 15:36:26] |
John - SC Support - Posts: 38292 |
To save to a new name, enter the name in the DTS Config field, then select the Save button. Then, in order to select one to load, go to the same DTC Config and find the configuration you want and select the Load button. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
