Date/Time: Sat, 01 Mar 2025 01:23:21 +0000
vp-dom problem
View Count: 435
[2021-09-10 07:12:01] |
User278398 - Posts: 291 |
hello, why the vp in dom still show me the volume from the last day ? (now it is 6 hours before opening trade (3:10 n.y usa)) i want to reset this vp, and show only volume from 9:30 when the trade will start (thats mean that now i need to see nothing) regards. |
[2021-09-10 08:28:27] |
now it clear some how, but i get data now although i order to see from 9:30 what is the problem? |
[2021-09-10 13:54:05] |
John - SC Support - Posts: 38292 |
As we noted in another one of your posts, you can not use that particular choice of VbP Graph Period Type (From Start Time to End Time) in the Trading DOM. It was overlooked as an item that needed to be locked out. We will take care of doing that, but in the meantime, you need to select a different Graph Type that is supported for the Trading DOM.
