Date/Time: Sat, 19 Sep 2026 06:08:15 +0000
MDI Window Tabs lags when switching Chartbooks
View Count: 1134
[2021-09-10 07:01:44]
User783093 - Posts: 27
Hi. I have this minor problem with window tabs that is very annoying.
Can't explain in words, please take a look a short screen recording: https://youtu.be/AnVIWNeAN6E
Is there a fix for this? I want them to be static and not appear/disappear when switching chartbooks.
[2021-09-16 05:41:22]
Anyone from Support?
Windows tabs are opening with a delay when switching chartbooks. How can it be fixed?
[2021-09-17 03:43:09]
Sierra_Chart Engineering - Posts: 24890
This is normal behavior.
[2021-09-17 06:38:48]
Can you make it static as chartbooks bar or menubar? It might seem unimportant, but it's had to tolerate when you switching between chartbooks 1000 times every day. I'm sure it's a pretty easy task for you guys. Please make it happen in future updates. Much appreciated in advance.
[2022-01-28 11:33:10]
User462086 - Posts: 202
The lag increases with the number of charts & the amount of data loaded.
Please consider providing a stable rectangle for the charts to inhabit: no shifting up & down when scrolling through chartbooks.
