Date/Time: Tue, 26 Nov 2024 00:34:33 +0000
Issue connecting to OEC
View Count: 1104
[2014-03-24 14:52:31]
GCAdmin - Posts: 35
I got this error when connecting to OEC on Friday, Same issue this morning. What do I need to do to fix it?
Software version: 1110 | 2014-03-21 20:21:39
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-21 20:21:39
Active service: Open E Cry FIX/FAST | 2014-03-21 20:21:39
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-03-21 20:21:39
2014-03-21 20:21:39 Local computer clock time | 2014-03-21 20:21:39
2014-03-22 00:21:39 GMT time | 2014-03-21 20:21:39
2014-03-21 20:21:39 Time zone adjusted time | 2014-03-21 20:21:39
Time difference to server time: 11 seconds. | 2014-03-21 20:21:39
Program path: C:\GreenChart\ | 2014-03-21 20:21:39
Data Files path: C:\GreenChart\Data\ | 2014-03-21 20:21:39
OS Version Number: 6.1 | 2014-03-21 20:21:39
Checking for new symbol settings for oec | 2014-03-21 20:21:39
Symbol settings are up-to-date for oec | 2014-03-21 20:21:39
Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-21 20:21:44
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-21 20:21:44
The network socket is connected. | 2014-03-21 20:21:44
Starting SSL connection on the socket. | 2014-03-21 20:21:44
SSL socket is connected. | 2014-03-21 20:21:44
OEC FIX Trading: Sending the Logon message. | 2014-03-21 20:21:45
OEC FIX Trading: Received a Logout message. | 2014-03-21 20:21:45
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-03-21 20:21:45
SSL shutdown indicates not able to send 'close notify'. | 2014-03-21 20:21:45
The SSL socket was shut down. | 2014-03-21 20:21:45
The SSL socket object has been freed. SSL state is now disconnected. | 2014-03-21 20:21:45
Socket has been shutdown and closed. | 2014-03-21 20:21:45
OEC FIX Trading: Logged out and disconnected. | 2014-03-21 20:21:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-21 20:21:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-21 20:21:45
Disconnected from Open E Cry. | 2014-03-21 20:21:45
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-21 20:21:45
File >> Disconnect selected. | 2014-03-21 20:21:46
Disconnected from Open E Cry. | 2014-03-21 20:21:46
[2014-03-24 17:47:58]
These are the relevant messages:
Refer to step 12 here for help with this:
https://www.sierrachart.com/index.php?l=doc/openecry.php#SetupInstructions
The webpage we have linked to has just been updated, so be sure to reload it to get the latest content.
Date Time Of Last Edit: 2014-03-24 17:48:22
