Date/Time: Sat, 01 Mar 2025 01:51:36 +0000
How to display lines (I think it is value area lines) on my TPO profile Chart ?
View Count: 449
[2021-09-10 06:49:54]
User918591 - Posts: 20
I will like to display lines on my TPO profile Chart as shown on the attached screen shot (not sure if they call it value area lines). Can you please tell me what to do to have those lines?
Regards,
imageimage.png / V - Attached On 2021-09-10 06:48:38 UTC - Size: 113.79 KB - 157 views
[2021-09-10 14:01:36]
John - SC Support - Posts: 38292
If it is the Value Area you are looking for, then refer to this setting:
Time Price Opportunity (TPO) Profile Charts: Extend Value Area
If it is the Initial Balance Range, then refer to the following:
Time Price Opportunity (TPO) Profile Charts: IBR Extension Display Mode
