Date/Time: Wed, 16 Sep 2026 01:55:03 +0000
[Programming Help] - Restart Spreadsheet study base on Regular trading Hours (RTH)
View Count: 1034
[2021-09-09 20:45:55]
Mario Escalante - Posts: 21
I'm using the following function:
=IF(ISNUMBER(SEARCH("09:30",D1)),"1","0")
my problem is that the SEARCH and FIND functions are for text only, so the formula won't return the desired value (1)
tried converting the value to text format, does not work
Any workaround for this problem? how can I set my spreadsheet study formulas to restart every day at 09:30 am. (RTH open)
thank you for the help
[2021-09-09 22:23:44]
Sawtooth - Posts: 4353
If you have a bar with the 09:30:00 timestamp, you could use this:
=MROUND(FRACTIME(A3),1/86400000)=TIMEVALUE("09:30:00")
If the 09:30:00 bar is the first bar of a new day, you could use this:
=INT(A3)>INT(A4)
[2021-09-13 16:47:38]
Tried #2 post, first suggestion unsuccessfully.
RESOLVED USING THE FOLLOWING FORMULA:
=IF(FRACTIME(A3)=TIME(09, 30, 00,0),1,0)
that will give you a (1) value everyday @ 09:30:00am
Thanks.
Date Time Of Last Edit: 2021-09-13 16:48:37
