Date/Time: Sat, 01 Mar 2025 01:27:38 +0000
BUG repport for STUDY - INITIAL BALANCE
View Count: 520
[2021-09-09 14:22:57] |
GravisHTG - Posts: 306 |
When you put the study on WEEKLY - number of days 1 . When the month is in the middle of the week , it wont restart the new week after the month. Or maybe something else , that is a deduction here the chartbook. |
[2021-09-09 17:03:37] |
John - SC Support - Posts: 38292 |
We are not seeing a problem with the Chartbook that you supplied. The Initial Balance starts a new calculation on Monday of each week. Can you please attach a screenshot showing what you are seeing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-09 18:38:08] |
here it is, and 1 put 1 week time line
Date Time Of Last Edit: 2021-09-09 18:38:30
[2021-09-09 23:02:32] |
We'll have to look into it, but the reason for that particular issue is because of the July 4th holiday being a Monday, which means there is no Monday data.
[2021-09-09 23:39:07] |
Is it possible to make the program understand that ? and then start on the normal open day for that particular week ?
[2021-09-09 23:49:44] |
Yes. That is what we need to look into and see why it is not already doing this.
[2021-09-10 13:00:22] |
BenjaminR - Posts: 172 |
A temporary workaround for this until the problem is resolved in the IB study, would be to use High/Low for Time Period Study. Save the study, so you can add it if & when there's another holiday week. At that time, in settings for that chart "hide" the IB study. Hope that helps. |
