Date/Time: Sat, 01 Mar 2025 01:29:02 +0000
Futures has been rolled over this morning although volume is very low on Z1
View Count: 556
[2021-09-09 13:13:53] |
User414371 - Posts: 9 |
Hi,this morning, SC has automatically rolled over the CME futures (such as NQ, ES, 6E to name a few) from U1 to Z1. The option 'Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume' is ticked. If you look at the attached picture, you could see that today, NQU1 has still 10 times more volume than NQZ1. So why has SC rolled over?
![]() Attachment Deleted. |
[2021-09-10 10:50:41] |
Sierra_Chart Engineering - Posts: 18607 |
Make sure this option is disabled: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) You must have it enabled. You will want to disable it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-10 10:51:08
