Date/Time: Fri, 28 Feb 2025 22:24:54 +0000
the software and the data is stop at certain time and is not working
View Count: 434
[2021-09-09 12:38:41] |
Andres Mourgues - Posts: 2 |
http://www.sierrachart.com/image.php?Image=1631191035279.png
[2021-09-09 12:41:51] |
You are using Interactive Brokers symbols. But Sierra Chart is not set to use Interactive Brokers. Did you want to trade from Sierra Chart using your Interactive Brokers account?
[2021-09-09 12:54:10] |
yes, like always ... i don't know why yesterday stop working
[2021-09-09 13:22:25] |
Follow the instructions here to set Sierra Chart to use Interactive Brokers: Interactive Brokers Trading Service: Setup Instructions It is not currently set that way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-09 13:22:37
