Date/Time: Tue, 26 Nov 2024 00:48:34 +0000
Stock after hours data
View Count: 1168
[2014-03-24 14:17:38] |
bwalks123 - Posts: 122 |
I have my TD Ameritrade connection setup on SC right now to analyze some stocks and I'm curious on how to show the after hours market data in SC so it matches charts with TDAmeritrade/thinkorwim charts?
[2014-03-24 16:58:07] |
Nothing special to do other than to set the Session Times to include 24 hours: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html#h7.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-24 20:12:43] |
Yes session times are set for 24hrs however when I pull up a 4hr chart on thnkorswim and then a 4hr chart on SC there seems to be a single bar missing. Prices match but candlestick bars do not. Does it have something to do with thinkorswim using 4 hour chart vs SC 240 min chart?
[2014-03-24 21:05:44] |
You may not be able to get an exact match with this. We really cannot help with comparisons to this other program. We recommend setting the Chart >> Chart Settings >> Session Times >> Start Time to what you require and see if that makes a difference. Here is the documentation: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
