Date/Time: Fri, 28 Feb 2025 21:51:44 +0000
Different Volume
View Count: 593
[2021-09-08 22:58:27] |
User536592 - Posts: 6 |
Hi, I noticed that my volume charts intraday is different from my daily volume charts. For example, adding up each volume bar on a 5min chart I dont get the total volume for the day (volume bar on a daily chart). Why is that?? Thanks |
[2021-09-09 16:27:23] |
John - SC Support - Posts: 38284 |
Refer to the following: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
