Date/Time: Fri, 28 Feb 2025 22:22:18 +0000
Combined Bid/Ask Market Depth Pulling/Stacking - Limit Number of Rows
View Count: 668
[2021-09-08 19:46:40]
RdUbz - Posts: 15
Hi, in the attached screenshot you will see I set a limit on the 'Maximum Market Depth Levels' to 10. You will see the Bid/Ask are only showing 10 rows of depth. However, the Combined Bid/Ask Market Depth Pulling/Stacking column still shows the entire book. I was hoping that I could limit the Combined Bid/Ask Market Depth Pulling/Stacking column to only show a number that I set (say maybe 5 or 10 rows) as the entire book of pulling and stacking is a bit much and probably a lot of data to process constantly. I checked everywhere yet I do not see any option to change this setting. I do not think that the Combined Bid/Ask Market Depth Pulling/Stacking column should be tied to the maximum market depth levels setting because some users may prefer to only see 5 levels Combined Bid/Ask Market Depth Pulling/Stacking, but wish to see 20 or more levels on the regular bid/ask.
Thanks!
imageSC-Combined Bid-Pull_Stack-Limit.png / V - Attached On 2021-09-08 19:45:21 UTC - Size: 96.82 KB - 220 views
[2021-09-09 16:19:49]
John - SC Support - Posts: 38289
Refer to the following setting:
Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
