Date/Time: Wed, 30 Sep 2026 15:02:01 +0000
Converting study alert formulae into dll file
View Count: 860
| [2021-09-08 17:03:20] |
| User202416 - Posts: 37 |
Hello Sierra Team Good morning . I created some study alerts and would like to convert in to dll file Kindly guide me how I can move forward I am having 2 accounts with Sierra chart level 5 package in India and US Thanking you in advance |
| [2021-09-08 18:16:42] |
| John - SC Support - Posts: 48069 |
We are not sure we understand exactly what you are looking for. The information for how to create a custom study starts here: Advanced Custom Study Interface and Language (ACSIL): Introduction And you may want to look at this particular section as well: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-08 18:34:12] |
Dear Mr John In case I create study alert with C>O ( last price is more than open price ) and Delta ID1.SG1 is -100 , I will create study alert with =AND(C>O,ID1. SG1<0) How to covert the above study in to dll file ? I only used simple study here for illustration purpose How to create study alert into dll file is my question ? Kindly reply whether it is possible or not ? Thanks |
| [2021-09-09 16:07:47] |
A DLL is an executable file that is run by the Sierra Chart system as a study. You can create a DLL and have an alert in it, but it does not make any sense to do so just for the one alert. The information we provided above is what you need to know in order to create the DLL. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-09 16:30:04] |
Dear Mr John Just for example u gave one study alert I have 100 study alerts in one chart Kindly guide me how to make all 100 alerts into dll file so that I can create dll |
| [2021-09-09 17:18:47] |
Again, the information we have given above is what you need. The only other thing we can point you to is the function for the alerts, which is the following: ACSIL Interface Members - Functions: sc.AlertWithMessage() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-09 17:47:46] |
I am too dumb abd you are too smart . You never understand the customers queues and always show your documentation. If you don’t know say that you don’t know . Don’t beat around the bush
| [2021-09-09 17:55:38] |
| Ackin - Posts: 1865 |
User202416) Creating a dll is not easy for a layman, if you care about having it in a DLL, then contact a paid third party programmer ... https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php |
