Date/Time: Sat, 01 Mar 2025 04:34:14 +0000
[Programming Help] - Hiding the inputs/subgraphs from users that aren't allowed to use the study
View Count: 458
[2021-09-08 16:41:19]
User907609 - Posts: 17
Is it possible to Blank the inputs (settings) and subgraphs from people that aren't authorized to use the study?
Example if an unauthorized user was to try and use the study below:
Date Time Of Last Edit: 2021-09-08 16:41:51
image5.PNG / V - Attached On 2021-09-08 16:39:17 UTC - Size: 7.01 KB - 180 views
[2021-09-11 15:12:03]
User99735 - Posts: 234
You can try doing the sc.IsUserAllowedForSCDLLName check in the if (sc.SetDefaults) section before the inputs are defined.
Regards
Vivek
[2021-09-17 15:00:53]
Thank you Vivek, Much appreciated!
