Date/Time: Sat, 01 Mar 2025 01:33:16 +0000
Cumulative delta bars
View Count: 597
[2021-09-08 08:44:32] |
User97684 - Posts: 136 |
Hi Pls help, Running 2 windows with historical depth, same settings. Cumulative delta can not be calculated, and there is a delay in the top chart... Many thanks |
[2021-09-08 16:35:41] |
John - SC Support - Posts: 38292 |
We are wondering if you are still having an issue with this, as there can be times when it takes a few minutes for the Cumulative Delta Bars to calculate. If you are still not having them display, then try reloading and recalculating the chart by selecting Edit >> Reload and Recalculate. If you still have an issue after that, then please get us a copy of that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-08 17:27:30] |
Hi John, Thanks - issue still there, but as I created a new chartbook to paste that particular chart to send to you, by moving the chart to a blank chartbook - it got fixed !! Then I pasted it back to orig CB , and is now fixed. ..... Date Time Of Last Edit: 2021-09-08 17:28:30
Private File |
[2021-09-09 13:43:08] |
Do you still have the chart that had the problem? If you do, can you attach that chartbook so we can take a look. You can always make the attachment private so only we (Sierra Chart) can see it.
[2021-09-12 11:27:23] |
Sure, thanks, The Attached Chartbook 1 has only the 2 charts that weren't showing the cumulative delta, or alrge volume indicator, when they were part of Chartbook FDAX 2021- charts #19, #21. After copying them to Chartbook 1 they immediately got fixed, but are still 'bad ' in CB FDAX 2021. If I copy them back from CB 1 to CB FDAX 2021, the 'copies' are fine, but the original #19, #21 are still withouth cumulative delta. |
Private File Private File |
