Date/Time: Fri, 28 Feb 2025 21:56:28 +0000
link drawing in charts
View Count: 1501
[2021-09-08 08:01:32] |
User278398 - Posts: 291 |
hello, there is option to link drawing between charts (with the same symbol)? |
[2021-09-08 11:13:52] |
Yes. Refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-08 14:25:04] |
hello, there is option to link studys between charts (i want to open all my group study in one chart, and to see all this group in my other charts (with the same symbol)? |
[2021-09-08 16:53:39] |
John - SC Support - Posts: 38285 |
Refer to the information on Chart Linking here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
