Date/Time: Fri, 28 Feb 2025 22:15:29 +0000
Duplicating Multiple Charts to a Chartbook does not work correctly
View Count: 597
[2021-09-07 20:27:51]
User260950 - Posts: 10
Hello support team
I duplicate chartbooks according https://www.sierrachart.com/index.php?page=doc/Chartbooks.html#DuplicatingMultipleChartsToAChartbook.
After duplication, I change the symbol in the new chartbook, but all values in the spreadsheet of the new chartbook are changing constantly - i.e. once the values of the original symbol are in the spreadsheet and then again the values of the newly selected symbol - in constant change...
Could you please give me a solution?
Thanks!
[2021-09-08 10:15:23]
This must be because a particular Sheet in that Spreadsheet window is being used by more than one instance of the Spreadsheet Study. You need to correct this. Each instance of the Spreadsheet study must use its own separate Sheet.
You can control that through this Spreadsheet Study Input:
Spreadsheet Study Inputs: Chart Data Output Sheet Number
Date Time Of Last Edit: 2021-09-08 10:16:29
