Date/Time: Fri, 28 Feb 2025 22:34:25 +0000
study group problem
View Count: 526
[2021-09-07 16:12:40]
User278398 - Posts: 291
hello,
can i add to a study group to another study group?
imageScreenshot 2021-09-07 191158.jpg / V - Attached On 2021-09-07 16:12:20 UTC - Size: 181.49 KB - 157 views
[2021-09-07 21:45:31]
Tonkadad - Posts: 235
Yes, you can. Check the "Prompt to Remove Existing Studies" box, Put a study group name in the drop down list, click "Save All". Then click "Ok" to close the window, select the chart that you want to combine the existing study group and new study group, then go to "Analysis" on toolbar and select your new study group (it should have a "+" at the end of it) click "No" when window comes up to remove existing studies. Then if you want to save the combined studies to a study group, wash, rinse, repeat.
