Date/Time: Fri, 25 Sep 2026 20:51:48 +0000
[User Discussion] - OHCL- problem
View Count: 773
| [2021-09-07 14:55:30] |
| User278398 - Posts: 296 |
hello 2 questions: 1. i want to see OHCL line on all the bar that show in the pic with out the first bar, how can i do it? 2. how can i progrem that i see all the OHCL line (in the pic) as extend? |
| Attachment Deleted. |
| [2021-09-08 15:04:49] |
| John - SC Support - Posts: 48027 |
1. You could use the Spreadsheet Study to check if the bar is TODAY() and if so, then set that data to 0. 2. There is not an easy way to extend all the lines. You can use the Extend Bar Value Until Future Intersection, but, as the title states, it will only forward until the next intersection. The only way to do this would be to modify the code and use the sc.AddLineUntilFutureIntersectionEx function and set the AlwaysExtendToEndOfChart to 0. Refer to the following: ACSIL Interface Members - Functions: sc.AddLineUntilFutureIntersectionEx() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-08 17:42:29] |
what is and how do i work with Spreadsheet Study?
| [2021-09-09 13:51:37] |
Refer to the following: Overview of Spreadsheet Studies: Introduction to Spreadsheet Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
