Date/Time: Sun, 13 Sep 2026 00:59:49 +0000
Number bars
View Count: 714
| [2021-09-07 13:12:37] |
| 12VMan - Posts: 58 |
I have attached a Numbers Bar study example. Three questions: 1) I have the delta in column 1 and Bid x Ask in column 2. The delta does not mathematically line up with the Bid x Ask. I'm guessing the Bid x Ask is being rounded, but I have Use Large Number Volume Formatting set to No. Is there another place to fix this? 2) How do I increase the space between the numbers bars? Spacing Adjustment Value truncates the numbers. 3) How do I increase the space between Column 1 and Column 2? |
| [2021-09-07 13:44:01] |
1. You may need to increase the chart bar spacing. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. 2. Refer to: Working With Charts: Changing Bar Spacing 3. There is not a way to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
