Date/Time: Fri, 28 Feb 2025 22:06:18 +0000
Create a candle chart based on custom period with conditions
View Count: 605
[2021-09-07 12:31:58] |
Enrico HL - Posts: 3 |
Hi, it could be a great feature to create candle charts based on custom periods with conditions e.g.: - print daily chart with with a candle for the overnight session, followed by a candle of the RTH session. - print daily chart based on combined data for the past 2 RTH-sessions followed by a candle for the past 2 OvN-sessions. Basically instead of having a fixed time period, the period is condition based and creates a candle. For each candle I would be able to use studies XYZ. Thx a lot! SC is the best! Date Time Of Last Edit: 2021-09-08 12:08:51
[2021-09-08 14:33:08] |
John - SC Support - Posts: 38287 |
This isn't something we would be able to get done any time soon (if ever). You can always create your own custom chart bars using ACSIL. Refer to the information here: ACSIL Interface - Custom Chart Bars: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-08 15:20:19] |
I thought about that but I wanted to ask at least anyhow. So this will be my first ACSIL project then (I was an iOS and MT5 dev. before trading..) Thx for the response. |
