Date/Time: Fri, 28 Feb 2025 21:38:54 +0000
downloading software failed
View Count: 396
[2021-09-07 11:47:44] |
User968625 - Posts: 260 |
I am trying to install a new instance from the software download and it keeps failing. trI stopped the antivirus software and it failed again. I just sent the log
[2021-09-07 13:50:40] |
Follow this method here to provide us the Installer Log: Software Download: Providing Installer Log to Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-07 23:46:47] |
I got it to work, thank you
