Date/Time: Fri, 28 Feb 2025 21:53:35 +0000
[User Discussion] - Program Transfer from 32 bit to 64 bit version.
View Count: 470
[2021-09-07 06:23:35]
User62933 - Posts: 17
Hello, I've just received a newer computer and installed 64 bit version (2299), but I would like to transfer the Global setting, Chart books, graphic and color configurations from my old 32 bit version. I know which files to copy per the FAQ page, but would like to know, if the 32 bit program settings will be compatible with the newer 64 bit program (2299).
Thank you.
[2021-09-07 16:42:50]
FYI, I just copied over the Sierra3.cfg (Renamed it to Sierra4.config), Accounts.config (Renamed it to Accounts4.config), and GlobalSymbolSettings, and Chartbooks from my old 32 bit program and it is working beautifully, and saved me a ton of time to reconfigure the program.
