Date/Time: Tue, 26 Nov 2024 00:43:56 +0000
OEC Connection
View Count: 1261
[2014-03-24 08:37:48]
User96015 - Posts: 55
Hi, I have a trial of OEC and I try to connect with Sierra Chart, But I' cant do it.
This is the message log:.
Software version: 1109 | 2014-03-24 08:32:45
Usage end date: 2014-04-14 | 2014-03-24 08:32:45
Enabled for: Sierra Chart Historical Data Service. | 2014-03-24 08:32:45
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-24 08:32:45
Active service: SC Forex Data (FXCM) | 2014-03-24 08:32:45
Time Zone: +00:00:00 (UTC+00) | 2014-03-24 08:32:45
2014-03-24 09:32:45 Local computer clock time | 2014-03-24 08:32:45
2014-03-24 08:32:45 GMT time | 2014-03-24 08:32:45
2014-03-24 08:32:45 Time zone adjusted time | 2014-03-24 08:32:45
Time difference to server time: 1 seconds. | 2014-03-24 08:32:45
Program path: C:\SierraChart\ | 2014-03-24 08:32:45
Data Files path: C:\SierraChart\Data\ | 2014-03-24 08:32:45
OS Version Number: 6.1 | 2014-03-24 08:32:45
Checking for new symbol settings for scfxcm | 2014-03-24 08:32:45
Requesting symbol settings for scfxcm. Overwrite = on. | 2014-03-24 08:32:45
Request for symbol settings completed. | 2014-03-24 08:32:46
Processed received symbol settings | 2014-03-24 08:32:46
SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-03-24 08:32:50
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-24 08:32:50
The network socket is connected. | 2014-03-24 08:32:50
SC Forex Data (FXCM): Connected to server. | 2014-03-24 08:32:50
SC Forex Data (FXCM): Sending logon request message. | 2014-03-24 08:32:50
SC Forex Data (FXCM) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-24 08:32:51
SC Forex Data (FXCM) - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-24 08:32:51
SC Forex Data (FXCM) - Successfully connected. | 2014-03-24 08:32:51
File >> Disconnect selected. | 2014-03-24 08:32:55
Socket has been shutdown and closed. | 2014-03-24 08:32:55
SC Forex Data (FXCM): Disconnected from the server. | 2014-03-24 08:32:55
Current selected Data/Trading service: Open E Cry FIX/FAST | 2014-03-24 08:33:27
Checking for new symbol settings for oec | 2014-03-24 08:33:27
Requesting symbol settings for oec. Overwrite = on. | 2014-03-24 08:33:27
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-24 08:33:28
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-24 08:33:28
Request for symbol settings completed. | 2014-03-24 08:33:29
Processed received symbol settings | 2014-03-24 08:33:29
Current selected Data/Trading service: Open E Cry FIX/FAST | 2014-03-24 09:33:48
Error received in OnConnect while connecting. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2014-03-24 09:33:49
Socket has been shutdown and closed. | 2014-03-24 09:33:49
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-24 09:33:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-24 09:33:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-24 09:33:49
Disconnected from Open E Cry. | 2014-03-24 09:33:49
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-24 09:33:49
File >> Disconnect selected. | 2014-03-24 09:33:49
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-24 09:33:50
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-24 09:33:50
Error received in OnConnect while connecting. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2014-03-24 09:34:11
Socket has been shutdown and closed. | 2014-03-24 09:34:11
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-24 09:34:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-24 09:34:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-24 09:34:11
Disconnected from Open E Cry. | 2014-03-24 09:34:11
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-24 09:34:11
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-24 09:34:14
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-24 09:34:14
Error received in OnConnect while connecting. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2014-03-24 09:34:35
Socket has been shutdown and closed. | 2014-03-24 09:34:35
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-24 09:34:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-24 09:34:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-24 09:34:35
Disconnected from Open E Cry. | 2014-03-24 09:34:35
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-24 09:34:35
File >> Disconnect selected. | 2014-03-24 09:34:36
Disconnected from Open E Cry. | 2014-03-24 09:34:36
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-24 09:35:18
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-24 09:35:18
Error received in OnConnect while connecting. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2014-03-24 09:35:39
Socket has been shutdown and closed. | 2014-03-24 09:35:39
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-24 09:35:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-24 09:35:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-24 09:35:39
Disconnected from Open E Cry. | 2014-03-24 09:35:39
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-24 09:35:39
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-24 09:35:42
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-24 09:35:42
File >> Disconnect selected. | 2014-03-24 09:35:43
Socket has been shutdown and closed. | 2014-03-24 09:35:43
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-24 09:35:43
Disconnected from Open E Cry. | 2014-03-24 09:35:43
Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-03-24 09:35:45
Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-03-24 09:35:45
Error received in OnConnect while connecting. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2014-03-24 09:36:06
Socket has been shutdown and closed. | 2014-03-24 09:36:06
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-24 09:36:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-24 09:36:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-24 09:36:06
Disconnected from Open E Cry. | 2014-03-24 09:36:06
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-24 09:36:06
File >> Disconnect selected. | 2014-03-24 09:36:07
Disconnected from Open E Cry. | 2014-03-24 09:36:07
Can you help me?
Thanks, Bye
Date Time Of Last Edit: 2014-03-24 08:38:15
[2014-03-24 08:52:18]
Refer to the response here:
OEC - SC version 1109 not connecting again | Post: 28980
