Date/Time: Fri, 28 Feb 2025 21:51:52 +0000
Volume by price reset question (multiple charts at once)
View Count: 442
[2021-09-06 16:00:32] |
User900285 - Posts: 97 |
I have 2 chart DOMs on separate instruments both with their own VbP study that I have set to reset with the VbP reset button study. Right now it works fine to reset the VbP on 1 DOM at a time. I would like to know if it is possible to reset VbP on 2 separate charts at the same time without having to click and select the other chart. I know this sounds very similar to the existing commands like "clear recent traded volume All symbols". What I have done is I am using a VbP study to show the delta of the current trades since this seems to be the only way to display this on the DOM and clear it with a button. Right now the reset works on whichever DOM I have selected. This is perfect but I am just curious if it's possible to clear it on 2 charts at the same time. Many thanks |
[2021-09-06 17:12:32] |
John - SC Support - Posts: 38284 |
Right now, the button only works for the one referenced Volume by Price study. It does not even reset all of the Volume by Price studies for a chart, let alone multiple Volume by Price studies across different charts. We have tagged this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
