Date/Time: Fri, 28 Feb 2025 22:31:54 +0000
Change ticker after clicking on chart in DOM or chart
View Count: 563
[2021-09-06 11:32:57] |
User247682 - Posts: 7 |
Hi I'm wondering if there is a way to automate or any study to do this. Let say I have 10 charts on my instance and I want quickly change ticker on my DOM or master chart for the one with I clicked from any of the 10 charts. Any chance to do it instead of manually changing?
[2021-09-06 11:44:18] |
The closest which is available is through Quote Boards and is documented here: Getting Quotes: Changing Symbol of a Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-06 23:02:56] |
User90125 - Posts: 715 |
Also you can setup a Watch List and select from its drop down list. Changing the Symbol of a Chart: Using the Associated Watch List |
