Date/Time: Fri, 28 Feb 2025 22:13:34 +0000
Technical indicator for value of RSI(2),RSI(5),RSI(15) and RSI(30) on a single day
View Count: 502
[2021-09-06 07:26:05]
User14410 - Posts: 38
May I ask is there a technical indicator which can show the aggregation result of RSI(2),RSI(5),RSI(15) and RSI(30) on a single day? Thanks.
[2021-09-06 14:24:11]
John - SC Support - Posts: 38288
If you are just wanting to add together the data, then the easiest way would be to use the Spreadsheet Formula study. Refer to the following:
Spreadsheet Formula
Or you can use multiple versions of the Study Subgraphs Add to add them together. Refer to the following:
Study Subgraphs Add
If you are looking for something else, then you may want to be aware of the Arithmetic Studies, which can be found here:
Using the Basic Arithmetic Studies
