Date/Time: Thu, 26 Nov 2026 20:58:02 +0000
saisonality or something like relative volume for different data
View Count: 833
[2021-09-05 16:30:13]
User146848 - Posts: 124
Does SC offer a study which makes it possible to create saisonal charts based on price, spreads ect.?
PS: Does SC have a study for calculating percentage values based on the data of another study? Didnt find it.
Date Time Of Last Edit: 2021-09-05 19:39:38
[2021-09-06 13:58:27]
We are not exactly sure what you are looking for here, but refer to the following for what we think you want:
Custom Calculated Symbols
You referenced the Relative Volume study in your title. This would be the study you would use. You can apply the study to other subgraph data. Refer to the information here:
Relative Volume: Basing Relative Volume Study on Another Study for Non-Volume Comparisons
[2021-09-06 16:03:06]
for example:
i want to use the "Commitment of Traders" study and calculate the percentage share of the commercials net position based on the open interest.
Then i want to use this weekly number and compare it with the same week over several years.
And then i want to get an average for every week over 3 years, 5 years, ect.
[2021-09-06 17:15:38]
You would want to use the Relative Volume study for what you want to do.
Just be aware that we do not have the "Commitment of Traders" information directly in our software.
[2021-09-06 17:24:09]
Got it.
Because i want to compare the percentage values and not total values, how can i do that?
[2021-09-06 18:05:03]
If the data is already in percentages, then it would seem that you do not need to do anything further.
If you want to get a percentage value out at the end, then refer to the Arithmetic Studies that allow you to add/subtract/multiply/divide data, which should give you what you are looking for:
Using the Basic Arithmetic Studies
Otherwise, let us know precisely what you want to do and we will point you in the right direction.
