Date/Time: Sun, 21 Jun 2026 23:27:52 +0000
is there an easy way to see the high and low of a 30 minute TPO subperiod on a TPO chart?
View Count: 650
| [2021-09-04 22:19:45] |
| User846936 - Posts: 3 |
Hello, is there an easy way to see the high and low of a 30 minute TPO letter period/subperiod on a TPO chart? Because the price increment is 2 ticks, and or because the price axis is compressed, I can't just look at the price axis to see the exact value of the high or low in a TPO letter period (subperiod). For example, in the TPO chart program I used to use, I could just hover over a specific letter, and those values would show in a box next to it. Is there any comparable functionality in Sierra Chart? Thank you.
| [2021-09-06 13:36:09] |
| John - SC Support - Posts: 46802 |
There is not a comparable way to do this in Sierra Chart. The only option would be to break out the TPO Letter/Blocks into their own columns and then look at the high/low for each column. Or, you could put on a bar chart with the same time parameters and get the high/low for each period from the bars. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
