Date/Time: Tue, 26 Nov 2024 00:33:24 +0000
Trouble opening a Chartbook
View Count: 909
[2014-03-24 01:56:17] |
Lawrence B - Posts: 11 |
Keep getting "Warning: Caught an exception during the pprocessing of a timer event" when I try to start up a Chartbook. I have been able to fix it by exiting Sierra and then reopening the Chartbook.
[2014-03-24 06:14:38] |
Do you know if you are using any custom studies? More information about this can be found here: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
