Date/Time: Fri, 28 Feb 2025 22:15:29 +0000
Accurate Trading System Back Test not able to find trades?
View Count: 474
[2021-09-03 19:34:56]
SabikiSensei - Posts: 76
I'm using multiple charts and multiple spreadsheets.
Compared to when I turn it on live simulation, my spreadsheet for trading study is able to find trades that it can not while using Accurate Trading Back Test.
For example, it found a trade this morning on live - but when I use Accurate Back test, it did not show up.
I also notice that when I use replay mode 'standard', depending on the speed, it will give me different order fill positions.
This is normal?
[2021-09-07 06:51:19]
Sierra_Chart Engineering - Posts: 18603
We do not know what the trading system is doing and what it relies upon and why there is an issue. This section here gives you information about things to check:
Automated Trading Management: Troubleshooting Automated Trading System Behavior
Yes this definitely can be normal and it depends upon how the automated trading system works.
Date Time Of Last Edit: 2021-09-07 06:52:51
