Date/Time: Fri, 28 Feb 2025 22:34:51 +0000
Request help with .dll study
View Count: 517
[2021-09-03 18:44:47] |
jbech96 - Posts: 39 |
I am having trouble adding a .dlll study. I have added the recompiled .dll study to my c:/SierraChart/SierraChartTransActMA/Data folder and have deleted all the older DLLs. I even renamed the study using no numbers and placed it in the Data folder. I have never had an issue adding .dll studies before. I do not understand why it does not appear when I go to Studies, Add Custom Study. See attached for .dll study I am having trouble with. |
Private File |
[2021-09-03 19:45:52] |
John - SC Support - Posts: 38292 |
We just tried the DLL on version 2296 and did not have any problems with it. We were able to see the studies and we were able to load a few of them (we did not try them all). If you are not already on the current version, we recommend updating to the current release and then try to the DLL again. One other note - we did see the Anti-Virus flag the DLL, but it did not do anything to it. You may want to ensure that your anti-virus is not modifying the file somehow. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-03 19:46:57
[2021-09-06 12:02:43] |
This is what my Message Log reads: Custom symbol settings values: disabled DLLs: JK-V1.2.dll, UserContributedStudies_64.dll Allowed protected custom studies: 2021-09-06 07:47:16.794 Does this shed light on why I am having trouble? |
[2021-09-06 14:31:36] |
Not at all. Those messages are perfectly normal showing that you have the JK-V1.2.dll in your data folder where it should be.
