Date/Time: Fri, 28 Feb 2025 21:56:11 +0000
Is it possible to have the INITIAL BALANCE study but for a montly basic on a Daily chart ?
View Count: 556
[2021-09-03 18:01:19] |
GravisHTG - Posts: 306 |
I try to mess around with the setting , even study overlay but I was not able to acheive that result ! I meant montly BASIS , not basic. thanks in advance. Date Time Of Last Edit: 2021-09-03 18:01:48
[2021-09-03 18:33:25] |
John - SC Support - Posts: 38285 |
Since the Initial Balance study does not have an option for Monthly, then the only way to get this would be to modify the code for this study to include a monthly option. the code for this study is in Studies6.cpp. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
